car running rich.
car running rich. Code 43
i'm also having a little problem w/ it running rich. I've found a few vacuum leaks that need to be fixed. Can I just tie into any vacuum hose. One of the sensors is broke and the vacuum port has just been plugged so when I hook up the new sensor I'll have to run a vacuum hose to it. The map sensor o-ring was missing so i replaced it and the car wouldn't start. I took it back out and it started. I just got the car so I'm taking care of someone else's mess. it's a 94 lx 4door w/ a z6 swap. Runnin off a p06 right now so no vtecage. Any input would be helpful.
Re: car running rich.
it's throwing a code 43 which says fuel supply system. code 10 iat. code 17 vss. any ideas. would the iat throw off the fuel system?
jbiel
11
01-11-2009 06:27 AM
Sohc Driver
09-21-2003 11:05 AM
