Connection/connector
Old Apr 3, 2010 | 01:04 PM
Steve LeB's Avatar
Default Connection/connector
97 accord 4cly I am looking for what a blue wire from the ac compressor to a connector on the fan shroud controls. The last time I touched that wire the motor started to sudder and it blew an ac hose. It might be coincidental.
Old Apr 3, 2010 | 01:16 PM
RICKSAUTOMOTIVE's Avatar
Default Re: Connection/connector
probably the ac fan wire for when you turn on the ac the fan kicks on but i could be wrong. can you post pics and i'll look it up. sometimes the diagrams i have a not easily clear instantly. yet somtimes thay are. i'll look anyhow. if you can post pics that will help
Old Apr 3, 2010 | 01:22 PM
Old Apr 3, 2010 | 01:23 PM
is that it (C209) in the post above?
Old Apr 3, 2010 | 01:25 PM
is the wire blue and red? or blue and yellow? or all blue?
Old Apr 3, 2010 | 01:31 PM
Steve LeB's Avatar
blue to red the reason I'm asking both wires seemed frayed going into the connector. I just wanter to know can I connect these wires directly to each other. And to find out what I might have done to cause the hose to blow?
Old Apr 3, 2010 | 01:33 PM
looks like the blue wire is just for the radiator fan motor. its with a black wire on a two-wire connector and harness to connector 209
Old Apr 3, 2010 | 01:36 PM
the red and blue wire appears to be for the AC thermostat. i wouldnt connect the blue wire and the red and blue wire together. can you repair the frayed wires?
Old Apr 3, 2010 | 01:39 PM
the connection you made and blew the hose is probably from a shorted out wire that couldnt blow the fuse or relay because it was by-passed from you connecting the wire and runing power around the relay or fuse
Old Apr 3, 2010 | 01:41 PM
the hose may have blown also because the expansion valve is stuck shut and the refrigerant cant circulate causing the compressor to just compress and compress till something blows
Old Apr 3, 2010 | 01:49 PM
Steve LeB's Avatar
thanks Just to be clear this is a blue wire from the compressor to a connector that has a red wire connected to it, this is the original I didn't by pass anything just touched the wire to see if that was the wire that went to the ac fan motor, because the fan wasn't on when I turned on the ac.
Old Apr 3, 2010 | 01:57 PM
the only all blue wire in the whole system i seen was for the fan. the compressor wasnt shown clearly but i didnt look at all the diagrams...i literally have diagrame for every connector on the car. theres a few hundred of them for that car alone. check out this next post real quick and see the wire from the radiator fan motor to C209. there are 2 C209s in the pic but one is for a black wire (ground)
Old Apr 3, 2010 | 01:58 PM
Old Apr 3, 2010 | 02:06 PM
heres another one i just found
Old Apr 3, 2010 | 02:19 PM
Steve LeB's Avatar
This is not the blue/black wire for the fan motor I don't see it on either diagrams. I just went down and cleaned off the wire powder blue connected to a red wire connected to the lower portion of the fan shroud. Not the top connecton to the fan motor.
Old Apr 3, 2010 | 02:28 PM
well i'm guessin you havent went to an AC shop for the hose to be replaced. your AC system should be evacuated and leak tested after the hose is replaced. no air can be in the system from you replacing the hose. but they would test your AC system after it is done. wish i could have been more help. i dont service ac systems so i just look over diagrams if i have questions but it sounds like someone has messed with the wires on your car. often all solid colors are what auto parts stores sell and people just use whatever they can to repair broken wires. this is just a guess on why your wire is solid blue there
Old Apr 3, 2010 | 02:35 PM
Steve LeB's Avatar
thanks for your help I have 2 97 accords and both have that blue wire leding from the compressor. I did change the hose today and will be bring it to a honda shop this comming week. I just threw the question out there to we what I was up against.
Thanks for your time and help.
Old Apr 3, 2010 | 02:54 PM
no problem
acuraown
Acura TSX
Jun 6, 2017 11:31 PM
carguy200550
Honda Civic (2001 - 2005)
May 3, 2014 12:03 PM
RAS Motorsports
Jul 8, 2003 05:32 PM
Butler230
Jun 26, 2003 09:33 AM
