OBD1 motor into obd2 car?????????
Old Apr 3, 2010 | 12:40 PM
96 EKCoupe's Avatar
TRIAL USER
Default OBD1 motor into obd2 car?????????
I have a 92 civic 4dr with a JDM D15b swap....but i just bought a 96 dx shell i was wondering how hard the swap would be to switch it into the dx....i have everything mounts,wiring, etc. fromt he 4dr will i need to change anything to swap in into the dx or will it bolt in and start up??
please help me with this
Old Apr 3, 2010 | 12:50 PM
jshu77's Avatar
Default Re: OBD1 motor into obd2 car?????????
Should mount up fine, you will probably have to change out drivers side upper motor mount. You'll want to spend some time researching the wiring. I think you will end up using an engine harness from a 96 ex an doing some modifying for the distributor etc. Then running a jumper harness for your ecu.
Old Apr 3, 2010 | 12:57 PM
96 EKCoupe's Avatar
TRIAL USER
I cant just use all the stuff from the d15? like the wiring harness? and the ecu?
Old Apr 4, 2010 | 02:28 PM
jshu77's Avatar
Uhh no you can't. The engine harness on the 92 4dr is totally different from the the engine harness on the 96 dx.
D-NWI
May 14, 2010 10:26 AM
dizzyek
Jan 27, 2006 02:00 PM
91civicmoneypit
Dec 3, 2003 02:17 AM
949eg
Jan 19, 2003 04:12 PM
