Choosing new wheels, there aren't and FAQ's on offset or wheel sizes.
Old Apr 3, 2010 | 12:06 PM
Romo Pyro's Avatar
Default Choosing new wheels, there aren't and FAQ's on offset or wheel sizes.
I want a stance like this:
https://honda-tech.com/forums/showpo...5&postcount=78
just wondering what kind of sized wheel/offset/spacer size I would need to accomplish this. I want a lip on the wheel like that. But flush at the same time and some camber. What do you guys suggest to make it look like that?
Old Apr 3, 2010 | 08:17 PM
RMOracer34's Avatar
Default Re: Choosing new wheels, there aren't and FAQ's on offset or wheel sizes.
I think it depends on how slammed you wanna be?
Old Apr 3, 2010 | 09:58 PM
smomo's Avatar
TRIAL USER
As a rough guide you would be looking at 15x8 +20 (or 15x8 +30 with a 10 mm spacer etc) and 2.5ish degrees of camber. Possibly need your fenders rolled as well depending on how low you are going. Hope this helps
Old Apr 5, 2010 | 09:17 AM
nsxtasy's Avatar
H-T Order of Merit
Sure there are. You just didn't bother looking, which is why you're deciding things backwards. It says:
Originally Posted by Forum Rules and FAQ - READ BEFORE POSTING
Wheels FAQ
I want to buy wheels. How should I decide what size to get?
You need to make your decisions in the following sequence:
1. Decide on a wheel diameter (15", 16", 17", etc) based on looks, performance, availability, tire availability, etc.
2. Decide on what tire size(s) work best with that wheel diameter on your car. For street use, this is normally the tire size that has the same outer diameter as your stock tires, and is no more than 10-20 mm wider than your stock tire size. See the Tire FAQ below for more information on how to choose the best tire size, including recommended sizes for the most popular Honda/Acura models.
3. Decide on which tire make/model you want to get, based on what's available in those size(s), and on what your needs are (performance, weather conditions, usage, budget, etc). Again, see the Tire FAQ below for questions to consider when finding the best tire for your needs. Feel free to create a topic on the forum to ask for advice.
4. Look up the specs for approved rim widths to help you determine the rim width for that model and size of tire. You can find the specs on the tire manufacturer's website or on the website of tire dealers like the Tire Rack. You should keep the rim width within the range of approved rim widths. You may want to pick a width in the middle of the range; the one at the widest end of the range may make the tire look a bit "stretched", and at the narrowest end may make the tire look "bulging". But anywhere in the range should be okay for safety purposes.
5. Find out the best offset for your wheels and tires, based on the rim width and your car. There's no magic formula; you may have to ask those who have tried different rims. Remember that offset depends on the wheel width, so a given number for a wheel of one width may position the wheel the same as a different number for a wheel of a different width. You can convert offsets to adjust for differences in width using this wheel offset calculator.
6. Then you can find out which wheels come in the rim, width, and offset you need, as well as the bolt pattern and center bore your car's hubs require.
Old Apr 9, 2010 | 06:03 PM
Romo Pyro's Avatar
^ my bad, I didnt do a proper search. Thank you very much though. That helped out a lot.
Old Apr 9, 2010 | 06:10 PM
Romo Pyro's Avatar
Yes it does, thank you very much. This will give me more of an idea of what my setup should look like with the resources I have, such as:
Im going to run 7.5" wide wheels wrapped in 205mm tires, (Which is the max allowed safely according to tirerack.com) and about +35 to +42 mm offset, and that way if I dont like it, I can get spacers to push out the wheels more.
https://honda-tech.com/forums/showpo...65&postcount=1
^ for the reference that I used.
danglesauce26
Jul 4, 2013 07:11 PM
ladies_first
Feb 9, 2013 04:23 PM
guy_from_nerk
Apr 2, 2011 04:57 PM
hybridb18
Apr 20, 2004 12:32 PM
al_r
Oct 26, 2003 01:04 PM
