reset the ecu?
Old Apr 3, 2010 | 11:09 AM
jphil101's Avatar
Default reset the ecu?
i was wonderin how u reset the ecu...my car has been throwin code 7,9,22 and 23...now i replaced the tps and installed it correctly and its been slowly getting better with each cold start but its still throwin the codes....the vtec works fine except it only lets me go to bout 7500 (b16 1st gen)...any advice?
Old Apr 3, 2010 | 11:14 AM
BiG ChOr!Zo's Avatar
Default Re: reset the ecu?
remove the negative battery cable for 10+ seconds and reattach...!!!
Old Apr 3, 2010 | 11:36 AM
saltypants's Avatar
Why waste time removing the battery cable when you can just remove the 10A Hazard fuse in the main fuse box for 10 seconds and achieve the same result?
Old Apr 3, 2010 | 08:51 PM
a&w's Avatar
a&w
TRIAL USER
or u can unplug the ecu
crxsi814
Jan 18, 2011 06:25 PM
98GSRrdr
Mar 20, 2007 11:17 AM
incubus
May 12, 2003 11:00 AM
LsPower
Dec 2, 2002 07:58 AM
jermothedrunk
May 29, 2002 10:04 PM
