Low idle and whistling...
Old Apr 3, 2010 | 10:23 AM
JasonYo's Avatar
Default Low idle and whistling...
Ok so I just searched alot but I'm still kinda confused here.
anyways, I got my timing belt\water pump changed recently, and now my engine idles really low (like 300rpm) and only at idle and when the car is warmed up it makes a high pitch squeaking noise, but when I give a bit of gas it goes away.
I'm thinking that my alternator belt is loose, since this only started right after I got the timing belt changed. My idle was fine before and there was no squeaking.
Also, how do you tighten the alt belt? Loosen the alternator and move it?
Thanks.
Old Apr 3, 2010 | 10:32 AM
tonyhatchetman's Avatar
Default Re: Low idle and whistling...
Bleed the coolant system and check for vacum leaks .......good luck
gokblok
Aug 1, 2013 04:20 PM
Raw B
Oct 30, 2006 07:38 AM
llevity
Jul 12, 2005 02:39 PM
pinoyboy204
Jun 10, 2004 03:28 PM
DIE DIE
Mar 22, 2004 01:33 PM
