Do i need to change my fuel filter?
I have a turbo d16 w/ DSM injectors, sometimes when i turn my car on it immediately stalls because it sounds like its not getting enough gas .. i have to step on my gas to rev it and even when i do that it feels like its dirty or clogged or something ... so i'm thinking its either
1. fuel filter
2. injectors.
3. fuel pump
i changed my fuel filter like 2 years ago .... any advice?
1. fuel filter
2. injectors.
3. fuel pump
i would probably go ahead and change it, thats what it sounds like to me... and the after u change it get a bottle of lucas feul injector cleaner and run through it to kinda clean up the other stuff
I sure hope you are NOT using the honda fuel pump.
the only way your fuel filter is clogged would be from shitty fuel, which is kinda hard to use without noticing. 2 years old is plenty recent for a fuel filter.
I am using the honda fuel pump ... i'm only at 6PSI and on a stock motor .. my tuner told me the stock fuel pump would be fine to use ...
your tuner is an idiot.
buy a walbro 190 or 255 fuel pump for 90 bucks.
the 190 will be quieter then the 255, and should be longer lasting.
your stock pump is ment to drive a 90-100whp car, not 180whp
hermtm2
23
Apr 8, 2009 06:17 PM
crnimacak
Apr 21, 2006 10:11 PM
The_In_Kid
May 15, 2002 12:33 PM
