Swapped out my B18a1 for a B18B. Problems...........
Old Apr 2, 2010 | 11:49 PM
jrose152's Avatar
Default Swapped out my B18a1 for a B18B. Problems...........
My 89 hatch came with a b18a1 in it. im swapping in a fresh built for turbo b18B. I've never swapped a motor before and just went out in my garage and did it. I'm pretty sure I have it completely put back together with the new motor in. It's pretty confusing at the end of the day because the intake manifolds and throttle bodys are dif from motor to motor. I'm trying to figure out where all of the VAC/fuel lines go and I'm pretty sure I don't have them all right on the b18B. Also, after I hooked everything back up I put the battery in backwards not paying attention and went to put the termanls on real quick. surprise, sparks, but only for a split second. I spun the battery around and checked fuses under the hood and none are blown. I hopped in the car and pushed the clutch in and tried to start the motor. Nothing. The injectors spray and so does the fuel pump. Lights/radio works so I know I'm getting power. But like i said, motor dosent attempt to start.
Here is a video of the code I am throwing.
http://www.youtube.com/watch?v=I8-O8_qEJn0
any suggestions?
Old Apr 3, 2010 | 12:02 AM
BadassEFdriver's Avatar
Default Re: Swapped out my B18a1 for a B18B. Problems...........
often the starter wont be able to crank over cus of lack of engine to body ground. Do you have it grounded? also check if your getting good spark from the plug, check if dizzy is good. are all sensors plugged in and swapped? are they both obd1?
Old Apr 3, 2010 | 09:23 AM
jrose152's Avatar
both motors are obd1 im almost positive. the b18B is a 94. where is the engine to body ground?
Old Apr 3, 2010 | 09:41 AM
alx_90ef's Avatar
you should of just used the same manifold.
and make sure the wire that goes from the harness to the starter is connected correctly.
and the one from the bat to the starter also
Old Apr 3, 2010 | 09:56 AM
jrose152's Avatar
yeah i have the two wires connected to the starter. i dident use the old manifold becuase this one is way cleaner and i had idle problems with my old one from cleaning the throttlebody wrong
Old Apr 3, 2010 | 09:57 AM
alx_90ef's Avatar
so it dont crank at all??
Old Apr 3, 2010 | 10:03 AM
jrose152's Avatar
no not at all, almost like the clutch isnt engaged when u try to start it but the clutch is down
Old Apr 3, 2010 | 10:30 AM
crx_si-r's Avatar
Check you fuses and grounds
Old Apr 3, 2010 | 10:31 AM
crx_si-r's Avatar
And make sure to have the correct firing order
Old Apr 3, 2010 | 11:19 AM
yes check all those grounds. positive to starter and battery to body ground. You should at least have 2 grounds going from the motor to somewhere on the body of the car..make sure you shave down some paint to get good enough ground. Ive known alot of people who's starter didnt wanna crank just cus they didnt have any engine ground. Is the starter cranking?
Old Apr 3, 2010 | 11:20 AM
and they didnt have this problem befroe ^ its comon for this problem to happen after a motor swap is done on a honda
Old Apr 4, 2010 | 07:45 AM
jrose152's Avatar
i forgot my killswitch was on haha
Old Apr 4, 2010 | 07:55 AM
speedooo's Avatar
doesnt crank=starter issue. if it cranked and didnt start then the possibility for a million other things opens up. did you remember to put it in the starter/fusebox/battery harness?
Old Apr 4, 2010 | 08:12 AM
jrose152's Avatar
i have a killswitch wired to my starter for security....i forgot to press the button
Old Apr 4, 2010 | 02:09 PM
brownsEF's Avatar
hahahaa good one
Neptronix
Dec 16, 2007 05:25 PM
kasperxtcy
Apr 10, 2007 06:40 PM
joshwhe
Apr 6, 2003 12:46 PM
94si94cx
Oct 23, 2002 07:38 PM
