air coming from oil fill hole. normal or blow-by?
Old Apr 2, 2010 | 10:01 PM
esedulerp5tenin's Avatar
Default air coming from oil fill hole. normal or blow-by?
i searched and didn't find anything in the prelude section, but in civic/teg/cord sections i'm finding this is normal.
i was immediately worried that my piston rings were fried, so i did a comp test and still 180 across the board (boosted F22). so i searched and found "every honda does this".
except i did this to my old mans '04 TL, and absolutely NO AIR what-so-ever comes out.
so is this normal or no?
Old Apr 3, 2010 | 09:12 AM
Enzo15's Avatar
Default Re: air coming from oil fill hole. normal or blow-by?
Some air will be normal, you will be able to feel it. What you do not want is excessive air, that would indicate excessive blow-by. All engines will do it, even brand new ones from the factory that have never been ran. Its caused by they fact that the rings never perfectly seal, partially because of the ring gap which allows stuff to flow past it.
Old Apr 4, 2010 | 08:14 AM
i would say its between normal and excessive. but a compression test would without a doubt pickup blow-by. sure two of the cylinders leaked compression a bit faster, but they were all between 177-180.
it just worried me cuz the '04 TL didn't have ANY air!! gonna go try with moms '00 TL right now haha.
Old Apr 4, 2010 | 09:15 AM
Enzo15's Avatar
well i dont kno wat kind of rings the TL has but there are these piston rings that are called gap-less rings. They work the way the name implies. They have only about 1-2% leakage, whereas normal rings have anywhere from 5-10% I believe. So I dont kno if the TL has those rings or not. The compression test will only really tell you if you have a problem with your rings/piston, or if the problem is in your head. For accuracy you would want to do a leak down test, which would tell you where you are having air leak.
Old Apr 4, 2010 | 09:21 AM
street_ride14's Avatar
how would a gap-less ring be able to be put onto the piston ? .. unless ofcourse if the piston has them built-in .. never seen a gap-less ring, don't think it exists, could be wrong though.
OP, the smartest thing you could do at this point is to check your compression and to install a vented catch-can setup, especially if you got turbo.
Edit: I just noticed you already did the compression test and got good numbers .. just install the vented catch-can setup and your problem should resolve.
Old Apr 4, 2010 | 03:29 PM
Enzo15's Avatar
I dont mean to be an *** but Gapless rings do exist. My engine building teacher game me a packet on the stuff. They still spread open and closed, but between the gap there is another smaller ring which helps close the ring. http://www.totalseal.com/ ......http://www.totalseal.com/SearchByApplication.aspx
Old Apr 4, 2010 | 03:37 PM
^ that's interesting.
Old Apr 4, 2010 | 04:03 PM
Enzo15's Avatar
Those rings have only 0-1% leakage when used... or so it says in the packet that came from the site lol.
Old Apr 4, 2010 | 07:31 PM
Apex1972's Avatar
didnt see anything for an Hseries motor?
Old Apr 4, 2010 | 08:15 PM
Enzo15's Avatar
O I looked at the link I posted, it doesnt show up the applications, just select Honda and for make it will be the third one from the top of the list.
Old Apr 4, 2010 | 10:52 PM
kkandreykk's Avatar
does anyone know how much psi does a stock h22a4 is supposed to have? i have 190 in each cylinder..
Old Apr 5, 2010 | 05:56 AM
Apocolipse269's Avatar
Yeah it's a typo, says "22a4" instead of "H22a4",
"2.2 VTECH 22A4, H23A1 2259CC"
thats for H series
Old Apr 6, 2010 | 09:20 AM
it'll vary depending on elevation, what kinda tester your using, and others, but yours sounds perfectly healthy. no worries.
but i'll try to do a leakdown when i can. if this motor is on its way out, i'm building a spare f22 on the side. oh wellll
dE.fUsEd
Apr 3, 2012 08:58 AM
Old goat
Nov 19, 2010 06:54 PM
Poey2
Jul 19, 2009 07:38 AM
crxtreme27
Jan 13, 2005 02:09 AM
mike2016
May 18, 2001 09:49 AM
