96-97 and 98-00 ek rear HATCH difference
Old Apr 2, 2010 | 05:48 PM
crx_253's Avatar
Default 96-97 and 98-00 ek rear HATCH difference
for 96-97 ek hatchbacks i know they have identical hatch/lock design and 98-00 ek hatch has the same locking mechanism were you can only open the trunk from the rear of the car, whereas 96-97 theres a release on the side panel
my question is would a 96 trunk work on my 98 civic hatchback. i know it would bolt on but if would it function correctly.. sorry if this has been covered already..
all input would be really appreciated
Old Apr 2, 2010 | 09:18 PM
96honda_EK's Avatar
Default Re: 96-97 and 98-00 ek rear HATCH difference
Actually 96-98 are identical. Its the 99-00 hatches that are different
Old Apr 2, 2010 | 10:03 PM
DAP97SI's Avatar
he is talking about the actual hatch on the car.
Old Apr 2, 2010 | 10:14 PM
Ruben19's Avatar
i know some 99-00 hatchbacks came with rear wiper blades.
the should all fit because is the same body design
Old Apr 3, 2010 | 01:08 AM
EJ6Hatchy's Avatar
actually ive got a 97 hatch and i cant open my hatch from the side lever. i have to take my keys out of my ignition, get the **** out and go all the way around to the back and open it from the lock on the outside of the hatch
Old Apr 3, 2010 | 04:36 AM
97H22AEK's Avatar
the inside trunk latch is cable operated and it sounds like it needs to be adjusted tighter or it's broke. I had the same problem only with my gas filler door. There was a plastic
"stop" piece right by the latch that was broken.
Old Apr 3, 2010 | 12:29 PM
crx_253's Avatar
on my 98 hatch i could only open the trunk for the the rear of the car i thought that was the same for 99-00 hatches too
Old Apr 3, 2010 | 12:31 PM
raidacaipo's Avatar
they are similar. Only difference is tail light and rear wiper blades depending on model for example dx or cx.
Old Apr 3, 2010 | 12:41 PM
jshu77's Avatar
A 96 hatch should work just fine on a 98. You could move over the lock assembly and the release handle assembly above the license plate from the 98. Personally I like the 98-00 lock and release setup better. The cable release on the 96-97 is on the car side and has nothing to do with the hatch so no issues there.
Old Apr 3, 2010 | 06:13 PM
NOFX's Avatar
H-T White Ops
From what I've seen (on here, IIRC), you can put a '98-'00 hatch on a '96-'97, but it requires quite some modification.
I think the problem was something along the lines of the latches being different sizes. Metal had to be cut in order for the other hatch to fit on the car.
I'd keep looking for a '96-'97 hatch instead.
And now to answer a few other things I saw mentioned in the thread.
The only differences in the rear of the '96-'98 hatch versus the '99-'00 hatch is the taillight design (color).
CXes did not have a rear wiper, but DX did. The CX also came with the unpainted stubby roof spoiler and the DX came with the two-piece, metal and plastic spoiler with the color matched top. This didn't change for the entire '96-'00 generation.
To the guy with the '97 who can't pop the hatch from inside the car, sounds like you might have a broken hatch cable or the cable has released from the latch or the interior lever.
Old Apr 3, 2010 | 06:17 PM
NOFX's Avatar
H-T White Ops
This might help a little.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/96-98-rear-hatch-door-into-99-00-hatchback-2447675/
Old Nov 28, 2021 | 09:22 PM
Alrickm33's Avatar
Premium Member
I have a 96, got a used 98 hatch, could I just swap the rear assembly with the hatches to fit into my 96? Thank you
Old Nov 29, 2021 | 08:19 AM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
Yes
Old Nov 29, 2021 | 03:17 PM
Alrickm33's Avatar
Premium Member
Originally Posted by CX-Adam
Yes
I just checked and realized you are wrong. Stop pretending like you know it all, you just wasted my time/money.
Old Nov 29, 2021 | 04:05 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
This was a 11 year old dead thread dug back up where most of the original posters are no longer active. Thread closed.
luckyjun127
Sep 17, 2009 06:31 AM
CMVTEC95
Aug 15, 2008 02:41 PM
EK SQUAD 425
Apr 21, 2007 03:42 PM
ek9tl
Jun 7, 2006 12:25 PM
Danger
Jul 13, 2005 03:30 PM
