Electrical Problems?? Help Please.
I have installed decks before so I am not that much of a rookie when it comes to car stereo. However, after everything I have tried and searching the internet and these forums, I am at a loss.
I bought a new deck. Removed the old one which was also aftermarket. Re-wired new deck to the original harness and it's not turning on. After checking the obvious things like fuses, connections, crossed wires, etc. I have found nothing that is wrong! So with much frustration I switched back to my old deck, which is not working any more either (previously no issues).
So, is there a seperate fuse or relay from the original wiring harness prior to the fuse box? This is the only thing I can think of since everything else is ok.
Now here is the other odd thing.. my keyless entry does not work now and I can not press the lock button to lock/unlock the car doors. I have to use the key and do it manually. I checked the fuses on this stuff as well. EVERYTHING is normal!
Any help would be appreciated! Thanks.
Figured it out.. Had a fuse blown not relating to the radio which made the radio and keyless entry not work..
Turbo Dan
Oct 13, 2005 09:10 PM
crawdad689
Audio / Security / Video
Dec 10, 2003 01:38 PM
