Need HELP with Suspension on a EF!! Please thanks
Old Apr 2, 2010 | 07:31 AM
ba_reefer's Avatar
Default Need HELP with Suspension on a EF!! Please thanks
Hey i just installed some megan sleeves on agx 4 way adj shocks on my 89 civic si. Im pretty sure i put the fronts in the front and the rears in the rear but i will swap them to find out. In the mean time my problem is the front lowers fine and the rear is all the way down on the sleeve but the car sits higher than stock!!! why is this? and is this normal. if this is normal what is a fix mayb shorter springs? if so who makes them? thanks in advance
Old Apr 2, 2010 | 07:32 AM
dacrxguy's Avatar
Default Re: Need HELP with Suspension on a EF!! Please thanks
Did you cut the bump stops?
Old Apr 2, 2010 | 08:59 AM
alx_90ef's Avatar
well i think you installed them incorrectly.
pictures maybe??
Old Apr 2, 2010 | 09:02 AM
brownsEF's Avatar
it would be pretty hard to put them on backwards icant see how u could put the back ones in the front
Old Apr 2, 2010 | 09:27 AM
alx_90ef's Avatar
dam i wonder what he did then
AH53-PaTh
Classic Hondas
10
Oct 21, 2011 11:35 AM
Mugenlude
Suspension & Brakes
Mar 26, 2010 08:39 AM
91hatchb
Apr 20, 2009 11:44 AM
daredeezy619
11
Mar 28, 2009 11:06 AM
GaMeOvEr
28
Nov 21, 2002 08:53 PM
