H22A timing
So QUESTION. when checking timing and TDC. does TDC mean TDC right before combustion? so when I have the flywheel and cams at TDC for cylinder number one, should the rotor in the dizzy be facing the wire for cylinder number one? and is cylinder number one the closes to the belts? or the opposite? please answer asap.
________
DODGE C SERIES HISTORY
..................................SO. when checking timing and TDC. does TDC mean TDC right before combustion? so when I have the flywheel and cams at TDC for cylinder number one, should the rotor in the dizzy be facing the wire for cylinder number one? and is cylinder number one the closes to the belts? or the opposite? please answer asap.
pcguy760
May 21, 2007 07:53 AM
92 in the works
Feb 23, 2004 07:30 AM
