ZC Cranks but I get nothing...
Old Sep 9, 2002 | 04:59 PM
BigDaddyRich's Avatar
Default ZC Cranks but I get nothing...
I can crank the ZC but I get no spark.
If the Cam Angle Sensor is wired wrong will it still start? I checked the suggested web pages but they give no detail about the Cam Wiring. the Cam Angle Sensor Plug has a Blue/Yellow and Blue/Green input wires... The Si Harness has a Blue and blue/yellow wires. I assumed Blue/Yellow matched with Blue/Yellow and blue matches with Blue/green. Can anyone confirm this? I will double check all the pin-outs tomorrow as its dark out now. IF anyone has any suggestions I'd appreciate it.
Also I am using a Civic Si Rotor. it was the exact size as the ZC and fit perfect?
Also I have yet to find the red/white wire in my Si Harness. I assume that if one wire is off on the re-pin the car will not start? or will it idle all rough and cut off?
Old Sep 9, 2002 | 05:12 PM
dustin's Avatar
Default Re: ZC Cranks but I get nothing... (BigDaddyRich)
Some of the wiring is wrong....
Old Sep 9, 2002 | 05:23 PM
zcivic91's Avatar
Default Re: ZC Cranks but I get nothing... (dustin)
could be a bad dizzy or wiring...
i think if the cam sensor is unplugged it will still run..
Old Sep 9, 2002 | 05:40 PM
PeTeY's Avatar
check your distributor wiring to see if you have the 2 white wires mixed. one is slightly thicker than the other one. switch these two and try to start it up.
Old Sep 9, 2002 | 05:46 PM
dustin's Avatar
Default Re: ZC Cranks but I get nothing... (PeTeY)
I've done this... hehe just recently too
Old Sep 9, 2002 | 06:30 PM
going outside to try it again
Old Sep 9, 2002 | 07:12 PM
OK according to the dmoore wiring diagram in their website... Since I have two white wires btw... I have no red/white .. (A thin white and a thick white) Where it says pin "C - White" does that correspond to the thick or the thin one? I tried both configs but no start
Also my CE light in the dash is flashing out a crazy code that doesn not even repeat itself. Anyone know where to find a ZC code list or can I use the Si code list since I have the Si ECU?
Old Sep 10, 2002 | 06:14 AM
keithv's Avatar
you use the ecu code for the corresponding ecu. so use the civic si ecu code list.
http://www.evotuners.com/civic_errorcodes.htm
Old Sep 10, 2002 | 08:22 AM
zexdrex's Avatar
i had problem starting mine and after redoing the wiring about 5 times i noticed the cam sprockets were off by allot adjusted them and it started right away . . . about two weeks later my distributor went and it wouldnt start either so maybe i could be a bad dist too hope it helps
Old Sep 10, 2002 | 08:24 AM
4gvtec's Avatar
well after we talked and found out that the thermostat housing ground was not hooked up,DOES IT RUN NOW!!!!!!!!!!!!
LET US KNOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 10, 2002 | 10:51 AM
dustin's Avatar
Default Re: ZC Cranks but I get nothing... (4gvtec)
Hehe that's important. It grounds the main relay to run 1) the ecu 2) the fuel pump
Old Sep 10, 2002 | 12:02 PM
No wonder I didnt smell gas ... although it was tumbling.... I will try to get her running tonight when I get home.
Old Sep 10, 2002 | 05:44 PM
Ahh... car started right up once I boosted the battery. It ran and idled good for about 30-45 secs then sputtered and died. Throwing a code #7 (throttle angle... I assume cause of the broken TPS) Now if I try to start it back up it just tumbles again. Do I have to reset the ECU before I can start it up again? Thanks for all your help guys. ITs almost 100%.
BDR.
zdelure
Jul 24, 2011 09:25 AM
h22_crx
11
Mar 9, 2006 11:49 PM
TommyBB
Sep 3, 2005 01:12 PM
sherfield2002
Dec 9, 2004 07:37 AM
1990hondaHF
Jul 25, 2002 09:06 PM
