extended wheel studs
Old Apr 1, 2010 | 09:16 AM
92bseries's Avatar
Default extended wheel studs
sorry did a search and i didnt get much, so ill try here and if it gets deleted, it gets deleted. every1 using arp extended wheel studs post em up, a whole wheel and studs shot, or like half a wheel w/ the studs so you know what wheel it is. again, sorry if its already posted
Old Apr 2, 2010 | 08:40 AM
92bseries's Avatar
Default Re: extended wheel studs
wtf, u mean to tell me all u hardcore jdmers dont have extended wheel studs??? u spend 2k on seats, and 700 on dumbass bys wings and no1 has extended wheels studs??????
Old Apr 2, 2010 | 01:41 PM
esoterEK..'s Avatar
lol.
Old Apr 2, 2010 | 01:46 PM
phunhaus's Avatar
Old Apr 2, 2010 | 07:50 PM
92bseries's Avatar
lol jus tryin stir it up so some1 posts their extended studs, but ya every1 here spends thousands on stupid seats and wheels but no1 has extended wheels studs, thats pathetic
Old Apr 2, 2010 | 08:26 PM
crx_91si's Avatar
this pic was taken from
pic request: Extended wheel STUDS!!
mike
Old Apr 2, 2010 | 08:35 PM
EJ_ALLMOTA's Avatar
On my EJ1
Old Apr 2, 2010 | 08:36 PM
Scott.'s Avatar
wow omg extended wheel studs!!! jdm as ****.
Old Apr 2, 2010 | 08:39 PM
Meoshe's Avatar
What is "JDM" about extended studs
Old Apr 4, 2010 | 05:28 PM
92bseries's Avatar
NOTHING, im jus comparing overpriced parts that arent hardly needed to wheel studs for racing/fast driving safety, thanx for the pix btw, any1 have studs with si wheels???
Old Apr 4, 2010 | 05:46 PM
josh-roy's Avatar
What kind of lug nut would you run.... the wrong one. But as long as you look cool who cares about how the lug nut is actually seated. FAIL.
Old Apr 4, 2010 | 06:44 PM
92bseries's Avatar
uhhhhh the proper one that fits the thread pitch, like a set of skunk2 open ended lug nutzzzzzzzzzz
Old Apr 4, 2010 | 06:47 PM
Micha's Avatar
FAILWGN
Are the skunk2 ones made for a stock wheel lug seating?
Old Apr 4, 2010 | 07:01 PM
92bseries's Avatar
im usin arp wheels studs, not oem ones, but idk y some1 would use oem studs with open ended lugs, but thats on them
Old Apr 4, 2010 | 07:31 PM
Sumslapper's Avatar
Year 3030
So you are trying to use extended wheel studs and run stock si wheels? You do realize that your awesome open end tuner lugs will not sit properly on a si wheel, right? Do you even know the purpose of extended lug studs?
Old Apr 4, 2010 | 07:36 PM
EJ_ALLMOTA's Avatar
you can barely see them but its there..
Old Apr 4, 2010 | 08:17 PM
dapek's Avatar
Extended wheel studs with skinny, stock wheels with a relatively high offset?? Your statements are ridiculously contradicting
Exactly what I was thinking
Old Apr 4, 2010 | 08:36 PM
pblockfinest's Avatar
niceee
Old Apr 5, 2010 | 04:24 PM
92bseries's Avatar
ur a fool shut up, get outta the thread, u act like im usin 13's with entended studs
Old Apr 5, 2010 | 05:21 PM
bluebomber's Avatar
Information Leafblower
Let me clarify some things for a couple people in here. BTW, these are all regardless of whether or not you have extended wheel studs.
1) If you are using OEM wheels, you need to use OEM lug nuts with a ball/radius seat.
2) If you are using aftermarket wheels, you need to use aftermarket lug nuts with a tapered/conical or flat seat, depending on the wheel.
3) If you want to run aftermarket lug nuts on OEM wheels, you need to run a lug nut conversion adapter. You can find them here: http://www.clubrsx.com/cr/SSR-WHEELWASHER.html
4) If you have extended wheel studs and OEM wheels, and you need an OEM open-ended lug nut, go to your local Honda dealer, ask for part number 90381-SV1-901 from a CRX Si model, bend over, then walk out with the PROPER lug nut for your car.
If you use the wrong lug nuts on your wheels, you will have problems due to the seat of the lug nut not making proper contact with the surface of the rim. If this happens, you lug nuts can fall off, which can lead to your wheel falling off.
Here's two handy pics from the Wheel/Tire FAQ:
Old Apr 5, 2010 | 05:46 PM
Sumslapper's Avatar
Year 3030
^^ Exactly what I was going to post but I was to lazy to look for it.
Old Apr 5, 2010 | 07:23 PM
josh-roy's Avatar
Thank you bluebomber.
Apparently its a very hard concept to grasp that OEM Wheels don't work with tuner lug nuts. Like i mentioned before, safety last kiddo's!...sheesh.
Old Oct 2, 2011 | 06:26 PM
PaRRoWMaN's Avatar
old...... but i just learned something.
Old Oct 3, 2011 | 04:46 AM
toyomatt84's Avatar
Sanji
1. Factory Honda wheels have a ball-type seat for the lug holes, so you'd either have to source adapter washers to run under your lug nuts converting them from conical seat to ball-type seat or run a ball-type seat open-ended lug nut (I have yet to find one, so good luck sourcing one).
2. Arguing a competitive gain for extended lug studs, then stating that you're using Si wheels is a rather massive contradiction. Si wheels will fit without them, and there really is no gain to be had over stock studs.
3. This thread is just going to breed more negative commentary, so I'm stopping it here.
allmotorek8
Suspension & Brakes
26
Jun 11, 2009 06:29 AM
gakkuken
21
Jan 10, 2005 02:28 PM
GreenR
Sep 12, 2003 01:49 PM
