How did you mount your race seat in your 5th gen?
Old Apr 1, 2010 | 09:10 AM
mkazm83's Avatar
Default How did you mount your race seat in your 5th gen?
Doesn't seem to much info on this topic.
Currently trying to figure out a mounting solution for a Cobra Suzuka (sidemount seat). I'm ~6' 2" and in the OEM seat, am slightly hitting my head on the roof with a helmet on. Vertical space is at a premium. I need to go down, at least a little.
I would love to be able to keep using sliders, if possible.
This is primarily a autox car that is driven to and from events. It is not daily driven.
Comments/suggestions?
Thanks!
Old Apr 1, 2010 | 08:54 PM
TheCirclingSky's Avatar
Default Re: How did you mount your race seat in your 5th gen?
You should check out Wedge Engineering.They make some mounting brackets.
http://www.wedgeengineering.net/
I can't tell by the picture on the website but it looks like you might need to buy separate sliders.
Old Apr 1, 2010 | 09:11 PM
93prelude615's Avatar
^ yes with wedge engineering brackets you are going to need seperate sliders
pretty much the only company to go with though.. for preludes at least..
Old Apr 2, 2010 | 04:46 AM
backwoods's Avatar
Used Wedge on my old Corbeau. Highly suggest you go with them
Old Apr 3, 2010 | 03:51 PM
ca86108's Avatar
yea wedge should have it. theres a guy selling some on ************ like 100$ for 2 brackets. usually they are 80 each
Old Apr 5, 2010 | 12:05 PM
117's Avatar
117
Sliders will remove quite a bit of headroom. If you want to get as low as possible, I'd either fab some plates that bolt into the OEM mounts and then bolt the side mounts into those, or replace the OEM mounts completely with square tubing and bolt the side mounts into the square tubing. I've done both, and I prefer the tubing that's welded into the chassis. Much more secure, IMO.
If you're the only one driving, not a big deal to lose adjustability.
Old Apr 5, 2010 | 03:48 PM
mkazm83's Avatar
Thanks for the responses.
I picked up a used wedge slider bracket, and some super low sidemounts to try out.
I cut the sliding bars off the bracket, put my sliders on, and that seems to be at about stock height.
Test fit pic.
I still need to do some fine turning, and get everything bolted/mounted together. Height wise, it'll be ok. With my helmet on, In the stock seat, I slightly rub my had against the headliner. I'm willing to deal with that for the amount of money I have vested in this setup.
If it doesen't work, I'm going to take 117's suggestion and hard mount it. It should be pretty easy to find a happy medium.
The reason I'm trying to retain some adjust ability, is because when I swap cars with people at autox it would suck if they were unable to drive it. It would also be nice to not have to drive to/from events crunched up.
Old Apr 6, 2010 | 06:46 PM
117's Avatar
117
I needed a lot of extra headroom in order to pass the 2" rule. No way would I be able to do that with sliders on the bottom of the bracket.
Old Apr 15, 2010 | 03:49 PM
mkazm83's Avatar
Just to update, I put all the stuff together and sit slightly lower than stock.
My head still rubs on the headliner (with helmet), but now does not rub on the sunroof sliding cover like with the stock seat.
List of parts;
Modified Wedge Engineering sliding bracket. (I cut off the 'slider' rails)
Unknown brand sliders. (looks to be some generic brand)
Low profile sidemounts. (similar to bride)
I'm glad I got the sliders to wrok. Without them, I wouldn't be able to get out of the car (without a quick release steering wheel).
Can't wait to try it this weekend.
laketboy
Jun 8, 2009 09:13 AM
darkstar1440
Jun 8, 2006 02:18 PM
trhoppe
Sep 28, 2005 11:07 PM
emwavey
14
Apr 27, 2004 02:14 PM
intense
Apr 14, 2004 07:08 PM
