INTEGRA BRAKE CONVERSION
Old Apr 1, 2010 | 05:00 AM
BigAnteg's Avatar
Default INTEGRA BRAKE CONVERSION
ive been searching on how to swap integra brakes on my eg but all i find is how to do the rear but im trying to find out what i need to do the front since ive already done the rear
Old Apr 1, 2010 | 06:03 AM
z6hatchboy's Avatar
Default Re: INTEGRA BRAKE CONVERSION
i would assume (dont quote me) that would just do the front knuckles, just dont get the itr ones because they have bigger axle openings in the hubs.? Also, a good proportioning valve might as well be added to get everything out of it.
Old Apr 2, 2010 | 09:21 AM
BigAnteg's Avatar
oh alright thanks for the help bro
Old Apr 2, 2010 | 09:33 AM
fallbacdun's Avatar
you need to get the prop valve from a del sol, brake booster from a non-abs teggy and also the whole front knuckle. just did gsr all the way around on my eg hatch, brakes so much better. should be able to reuse the lines and all straight bolt up, gl.
Old Apr 2, 2010 | 10:26 AM
BlueIntegraBoy's Avatar
It's simply remove the old knuckle and install the new one. Make sure you get a 15/16" master cylinder from a 94-95 Integra RS or 90-91 Civic EX. Bleed the brakes and go.
Old Apr 2, 2010 | 11:46 AM
American.Graffiti's Avatar
Correct. The only thing I would add is installing a 30/30 or 40/40 prop valve if you don't have one installed already.
Old Apr 2, 2010 | 06:48 PM
thumper64's Avatar
At least look into the 11 inch conversion you can do to stock "DX" knuckles first. You can put ITR calipers and rotors on.
Also I think it was just the JDM Type Rs that had the larger axles, not the USDM cars.
Old Apr 5, 2010 | 08:05 AM
BigAnteg's Avatar
oh okay cause i have the calipers and rotors i just need to find the knuckle now and i got a prop valve off a dc2 when i did the rear swap .... how much diff does it stop over the stock eg brakes is it much diff
Old Apr 5, 2010 | 08:07 AM
BigAnteg's Avatar
do i still need to change the master if i changed out the prop valve
Old Apr 5, 2010 | 09:08 AM
boxeocampeon's Avatar
i actually wanted to do this to my ej8
Old Apr 5, 2010 | 02:13 PM
cyrusli's Avatar
I would change it, it's about a inch thicker than the original EG one, it helps.
as for your earlier question, yes it does.. just think of it as a semi big brake upgrade for the car, more braking surface, shorter stopping distance. If you've gone up to a b18 or higher engine swap, then yeah, it'll be nice.
Old Apr 5, 2010 | 06:52 PM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
The above responses have answered everything but here's a good write up someone else did. I haven't done my conversion yet but I have all the parts. Now I just need the time. Good luck with yours!
http://www.hybridautomotive.com/tech/5lug/
Somalie187
Suspension & Brakes
Jun 27, 2011 09:16 PM
b18c1del
Suspension & Brakes
Jul 15, 2010 06:28 PM
jakfrost84
10
Mar 20, 2009 11:22 AM
MyEG6
Suspension & Brakes
33
Nov 21, 2005 07:29 AM
EG2 SiR
Oct 5, 2003 03:48 PM
