Ground Control ??
Old Sep 9, 2002 | 04:07 PM
pucho's Avatar
New User
Default Ground Control ??
Im about to purchase a set of GC coil overs to use with some AGX's. I hava an EK and Im getting the shocks for it, but for economic reasons I am thinking of purchasing the Special edition kit for the DC2. My question is will it work OK on my EK? I the only diffrence the spring rates? Also I purchased neuspeed urathane sway bar bushink kit but the bushings are for a 24mm sway bar and I am looking to install a EX 22mm bar, can I use them with the 22mm bar? Anny info will be appretiated. Thaks in advance.
Old Sep 9, 2002 | 04:51 PM
pucho's Avatar
New User
Default Re: Ground Control ?? (pucho)
Old Sep 9, 2002 | 04:56 PM
Eee Pee's Avatar
Don't cheap out. And most importantly, get the spring rates suited for the shocks, your driving, and what you plan on doing later. That way you won't have to do it again months from now.
Old Sep 10, 2002 | 01:47 AM
pucho's Avatar
New User
Default Re: Ground Control ?? (E Prepared)
Thanks for the opinion the point is well taken. Any one else?
Old Sep 10, 2002 | 02:36 AM
deviant1's Avatar
as for the spring rates, depends on driving style and comfort. performance or comfort. integra spring rates would be stiffer. if i remember correctly, i think you can use DC suspension products on EKs. someone correct me if im wrong.
BOTAN01
Jan 23, 2008 05:46 PM
deviant1
Apr 14, 2004 06:03 AM
deviant1
Mar 26, 2004 03:42 PM
pucho
Sep 10, 2002 09:11 AM
pucho
Sep 10, 2002 02:32 AM
