Ground Control ??
New User
Ground Control ??
Im about to purchase a set of GC coil overs to use with some AGX's. I hava an EK and Im getting the shocks for it, but for economic reasons I am thinking of purchasing the Special edition kit for the DC2. My question is will it work OK on my EK? I the only diffrence the spring rates? Also I purchased neuspeed urathane sway bar bushink kit but the bushings are for a 24mm sway bar and I am looking to install a EX 22mm bar, can I use them with the 22mm bar? Anny info will be appretiated. Thaks in advance.
Re: Ground Control ?? (pucho)
Don't cheap out. And most importantly, get the spring rates suited for the shocks, your driving, and what you plan on doing later. That way you won't have to do it again months from now.
as for the spring rates, depends on driving style and comfort. performance or comfort. integra spring rates would be stiffer. if i remember correctly, i think you can use DC suspension products on EKs. someone correct me if im wrong.
deviant1
04-14-2004 06:03 AM
