HIGH IDLE!!!!!!!!
Old Mar 31, 2010 | 07:10 PM
§95HATCH§'s Avatar
Default HIGH IDLE!!!!!!!!
Just bolted up a new Skunk2 intake manifold, and throttle body onto my B18a1. After I got everything done and started it up my idle after warming up was just under 3k. The thorttle cable is all the way backed off, and the set screw is also. In the morning I will be back at again, but i'd like some ideas before hand.
Thank you
Old Mar 31, 2010 | 07:17 PM
SiRJoEy's Avatar
Default Re: HIGH IDLE!!!!!!!!
You have a intake leak. Get some brake clean or carb clean and spray around manifold and t/b while car idling.When rpm drops you have found where it is leaking from. Gl
Old Mar 31, 2010 | 07:21 PM
crxxor's Avatar
I would start by checking your vacuum lines, especially the PCV. This is usually the culprit causing a higher than normal idle and smoke out the muffler. You can just simply unplug it and notice the difference right away, as the idle should start to lower.
Also, just because the throttle cable is all the way backed off doesn't mean that there isn't any tension. You have to account for the cable's mounting bracket, which could be mounted to far away, though unlikely.
Old Mar 31, 2010 | 07:23 PM
§95HATCH§'s Avatar
Thanks i'll check it out in the am.
Old Mar 31, 2010 | 07:52 PM
grog's Avatar
look at the throttle body make sure its fully closed. and be careful if you plan on spraying carb cleaner on your hot motor, it is flamable.
double check all your work.
did you torque the intake studs in the correct sequence and torque spec?
Old Mar 31, 2010 | 10:45 PM
EF_9's Avatar
i remember cleaning my FITV; it helped
ONECLEAN91
Mar 16, 2011 04:58 AM
Lethal001
25
Jun 16, 2008 04:49 PM
egCoupe
10
Aug 12, 2005 12:54 PM
civic dx
Aug 25, 2004 03:10 PM
passingthrough
Mar 27, 2004 10:32 PM
