weird starting issue!
Old Mar 31, 2010 | 05:28 PM
5557billetwheel's Avatar
Default weird starting issue!
I have a wierd starting issue with my turbo d16. when it's cold out under 50 degrees outside temp the car starts no problem and runs perfect,but when it's over 50 degrees outside temp i turn the key to on and the cel stays on the car will crank over run for a sec and die. I replaced the main relay thinking it was that but no change. I got the car in trade so I don't know much of what is done to it but as far as electronics i know of is neptune rtp/p28 ecu obd2-obd1 harness,gm 3 bar map sensor,aem wideband. I can't find the plug to jump to get the codes either.
Old Apr 1, 2010 | 10:01 AM
Default Re: weird starting issue!
anyone?
Old Apr 1, 2010 | 10:58 AM
imissmyhonda's Avatar
u check fuel pressure?
TexasRoller
Aug 15, 2012 04:38 PM
onthagozc
32
Aug 24, 2009 07:54 PM
roflcopterdown
Apr 16, 2008 02:15 PM
willyboyK20
Jan 4, 2007 07:07 AM
illestrolla247
Apr 4, 2005 06:24 PM
