Fuel or Ignition Problem?
Old Mar 31, 2010 | 12:30 PM
smokey68321's Avatar
Default Fuel or Ignition Problem?
i had to change my dizzy cause it was bad new one on and runs a whole lot better but when driving long distances the car bogs down like its loosing power then picks back up and is fine for a while then does it again and it has a slight backfire when changing gears any idea on what this problem is?
Old Mar 31, 2010 | 12:56 PM
runnamukk's Avatar
Default Re: Fuel or Ignition Problem?
Timing is likely off. Did you remember to remove the jumper?
Old Mar 31, 2010 | 02:50 PM
see i knew the timing was off cause of the slight back fire but can that cause the boggin down and pickin back up? .... the jumper?
Old Mar 31, 2010 | 02:54 PM
dephtone's Avatar
There is a jumper on the pass side shock tower for re-timing.
Sounds like you are a tooth or so off on your timing belt. If it is missing sometimes, I would check that because the back firing is not good for the motor.
Do you have any CEL?
Old Mar 31, 2010 | 07:32 PM
dannysolis92005's Avatar
double check the igniter on your new dizzy. i had the same problem, changed out the igniter and it stopped.
Old Apr 1, 2010 | 09:39 AM
ok so no CEL and still havnt checked ignitor and i was wrong about timing it is off by one or two teeth
Old Apr 18, 2010 | 05:20 PM
ok i really need to know or show me a picture of where this jumper is
deezknuts
14
May 13, 2014 01:41 PM
Built2NV
May 8, 2011 08:19 AM
DraginTeg93
Jan 29, 2010 12:02 AM
JDM-Riders
Apr 8, 2008 03:03 PM
