Threads on the oil pressure switch - what type?
Old Sep 9, 2002 | 03:36 PM
jthelman's Avatar
Default Threads on the oil pressure switch - what type?
On my d16, I'm using the output for the oil pressure switch as the oil supply.
The threads for this are either BSPT or BSPP - anyone know which one it is?
Thanks,
John
Old Sep 9, 2002 | 03:38 PM
paulzy's Avatar
Default Re: Threads on the oil pressure switch - what type? (jthelman)
it's the first one
Old Sep 9, 2002 | 04:18 PM
boomslang's Avatar
Default Re: Threads on the oil pressure switch - what type? (paul_vang)
it's the first one
Yup, 1/8" bspt.
Old Sep 9, 2002 | 05:26 PM
linx's Avatar
it is 1/8 inch british standard pipe taper very similar to npt in apperance but not the same.
Old Sep 9, 2002 | 05:41 PM
KiddEng's Avatar
Default Re: Threads on the oil pressure switch - what type? (linx)
what is the diff between them? what if u used npt instead of the bspt?
Old Sep 9, 2002 | 05:43 PM
Firedrake's Avatar
Default Re: Threads on the oil pressure switch - what type? (KiddEng)
NPT will go in fine, I have some autometer braided line threaded in there right now at 1/8 NPT.....dunno what problems this causes tho, but I've never had any leaks....
Brian
letsclique
Sep 18, 2010 07:23 AM
Gsir8
Jun 29, 2007 04:46 AM
doublejz
Jan 1, 2004 09:46 PM
