Proportioning valve high pressure release?
I discovered that the DUAL PROPORTIONING valve, on my 1994 Honda Civic LX 5-speed, leaks while I apply compressed air when 'bleeding' the brakes. It leaks fluid through, what appears to be a check valve. It only leaks when I 'bleed' the brakes w/ compressed air (applied at the fluid entry - brake booster) see attached pic.
Is this normal?
Is this normal?
Did yours leak when you bleed the brakes? Did you use compressed air on the reservoir?
Mine acted like it was a high-pressure release and a steady stream of hydraulic fluid flowed out, while under pressure.
SkRiBLaH
35
Sep 26, 2005 06:18 AM
mingbling96
Dec 20, 2004 10:19 PM
acura, broken, civic, dual, high, honda, hondadual, hondatech, leak, pressure, proportion, proportional, proportioning, release, valve
