99 dash into 96-98. what do i need from the 99??
im tryin to convert my 97 civic dash into 99 dash, what should i get from the 99?
thanks..
thanks..
From what I've read/heard, the 99 climate control center section fits right in...not sure about wiring harnesses though....the gauge cluster will just slide right in place...harnesses should be the same in you 97 as the 99.
you will need all of the 99-00 ac wiring and components. The 99-00 uses a turn dial for the climate control, which is electronic. the 96-98 uses the slide, which is not.
the plugs are different. so you are better off finding the complete ac/heater/blower motor/bezel/switches for the 99-00 off of one car. so you dont have to piece it together.
you just need the heater core, blower box, center air vent, climate control, heater core harness.
actually, all the items you need are in this thread:
https://honda-tech.com/forums/showth...605432&page=13
DunnDunn
Dec 23, 2008 11:45 AM
Mike Ockhurts
19
Mar 13, 2003 04:50 PM
