s300 completely dead..
Hello it seems somehow my s300 and my ecu got damaged a component on q34 on a p72 ecu is fried. Also the s300 will not light up or anything when placed into a good working ecu I am posting the pictures in hope someone can shed some insight on how screwed I am or if the s300 can be repaired.
Physically it looks just fine, no burns anywhere on it but I just wanted to ask ive done electronics repair before but usually there are physical signs of damage. This time is nothing.
Anyways I added the pics showing the damage to the ecu and pictures of the s300, hopefully someone can chime in.
Thanks
Thanks
Hondata will look at and possibly repair the S300 for a fee, I believe. If there's extensive damage I think you may need to purchase a new one. I'd give them a call to find out for sure.
Contact the dealer you purchased the system from for information on the Hondata warranty.
99% of the time that q34 is burnt it is because the customer has something improperly wired/hooked up on your engine harness which caused the failure.
Check your EGR/Intake air temperature wiring.
Also, check your intake air temperature sensor as it may also be damaged.
Yeah I saw a email on their site and I sent it their way to see how the process works, I found the component on the ecu on xenocrons site so I might be able to save the ecu if nothing else.
Thank you for the input I will look for a number on their site if they do not reply quickly via email.
Q34 blowing shouldn't have caused any damage to the S300. If you installed it into a known good ECU and it still doesn't work there is definitely a problem!
Or is there another reason you think that it cannot be repaired? Not saying you are wrong just attempting to get some insight.
It was late last night so I tried it again this morning and there was no lights on the s300 but when I plugged it in the PC via usb the PC did detect it but saw it as a unknown device and could not configure it. =(
Shame on me for not realizing we were talking about the wrong component. Q31 is the one that the PCS uses, not Q34. Sorry!
But its q34 thats blown =p but anyways I guess I had the s300 installed by off a prong because I got it to work after I installed it again.
The burnt ecu works as well is not throwing any CELs or anything..I checked the IAT sensor and the wiring and everything is okay so I am not sure what happened..
Either way thanks for putting up with my stupidity haha
HAMOTORSPORTS
Performance
783
Jan 19, 2013 12:45 PM
vy3tnamezz
Engine Management and Tuning
Sep 20, 2009 10:43 AM
BoostedH23a1
Jun 26, 2003 03:32 AM
