95 Del Sol, feels like running on 3 cylinders? (Video inside)
Old Mar 30, 2010 | 09:02 PM
aleks77's Avatar
Default 95 Del Sol, feels like running on 3 cylinders? (Video inside)
hey guys, posting for a buddy of mine, his car is a 95 del sol, its running like crap, NO power whatsoever. Did compression test its 190 accross all cylinders.
In the video, he accelerates in 1st gear, WOT, pedal to the floor. There is no power, and it sounds like a subaru lol. If anyone has any ideas, would really appreciate it! Thanks a lot!
http://www.youtube.com/watch?v=_7cFMDSgQ9U
Old Mar 30, 2010 | 09:29 PM
1LowSol's Avatar
Default Re: 95 Del Sol, feels like running on 3 cylinders? (Video inside)
Have you tried checking the timing.. Sounds like it's off about 20 teeth. Orrr if that's not it.. Check the fuel injectors..
Old Mar 30, 2010 | 11:16 PM
95soul's Avatar
That definitely sounds like a timing problem.
Old Mar 30, 2010 | 11:26 PM
aleks77's Avatar
i havent checked anything myself, but he says, the ignition timing is good, and when he lines up the 2 cam gear marks they are both identical 90 at 3 and 9 oclock to the valve cover. And the crank pulley lines up.
2006ser
30
May 7, 2011 06:35 PM
v-tecleta
May 29, 2006 04:57 AM
