Autolocks issues
my passenger door wont unlock from the alarm or the driver side.
the door light switch works fine. Unlock works on the driver side but not the passenger side. this just broke about 20 minutes ago.
What could this be?
What could this be?
alright, i found it. its the entire locking mechanism that needs to be pulled. anyone have any directions for it? looks like the window track is blocking it too, that might need to be pulled. and all the levers connecting to it.
and i am getting a 12v spike when i hit the alarm, so the wiring is good
I've been needing to do mine for a while, now. I've been putting it off for various reasons. Mainly because it isn't bothersome.
I remember seeing pictures of someone using an aftermarket (ebay) actuator. They had to mount it in a strange position, but they're dirt cheap and it functioned properly. I'll poke around for it.
btw, I greased up the window track and it still closes slower than my drivers side window. made an improvement but not by much.
Should I apply grease to the side tracks as well?
just buy a new actuator + lock assembly from majestic honda for $40. my driver side one lasted me 7 years before it failed.
Ahaha .. I meant that I would poke around for the picture, not the actuator.
I've already got a replacement (the whole door, actually) but I've been too lazy to swap the assembly.
yeah its very common on the 7th gen to have the actuator fail..i get alot of customers at work that ask about there door lock on there civics im not so sure on how to remove the actuator but it should be pretty simple by looking at how everything is attatch and then disassemble it after market actuators would work but it would mount weird id stick to the oem ones
I didn't need one when i changed my actuator. I think the key to getting the screws out is to have the proper philips screw bit. I believe you need one that's larger than the standard #2 philips. The screws will strip if you try to unscrew them w/ the wrong size bit.
Hmmm.. then I don't know what the deal is with mine. I gave 'er a try with a philips and they weren't gonna budge. Rather than stripping them or looking around for one of the impact drivers, I just gave up on it.
Now my biggest obstacle is my storage unit. The spare door that I picked up is buried near the back.
It goes without saying that I'm in no hurry to swap the actuator, ahahaha! It's a low priority fix.
But yeah I would use a ratchet to break the screws. Maybe spray a little WD-40 on there to help them out.
lpozzo
Dec 12, 2017 03:52 AM
professorman
Sep 17, 2013 09:27 AM
GarySeven123
Feb 16, 2013 05:21 AM
pliskin8
Jul 21, 2012 02:04 PM
