Blinker nose won't stop!!!!
Old Mar 30, 2010 | 06:10 PM
marine0621usmc's Avatar
Default Blinker nose won't stop!!!!
hey everyone. I have a 95 Acura Integra GSR. There is this ticking noise that sounds like the blinkers even when the blinkers are not on. All turn signals and hazard lights work perfectly fine when I use them. The blinkers sound go off as soon as I open the door and continue for a short period of time. When I drive the car, it stays on the whole time. I've tried checking all the fuses and removing the flasher but it still stays on. If anyone has experienced this problem or has an idea of what it may be please let me know. I would appreciate it because I don't know what else it could be.
Old Mar 30, 2010 | 07:49 PM
hondaluver19's Avatar
Default Re: Blinker nose won't stop!!!!
Where does it sound like its coming from? Cause it sounds to me that it might be a bad relay. But it depends on where its coming from.
Old Mar 30, 2010 | 07:56 PM
Spawne32's Avatar
thats a relay but not necessarily the one for the turn signals, the relay would only click if power was being applied to it, you need to narrow down which relay it is by listening closer for that noise
Old Mar 31, 2010 | 10:32 PM
sjbmx's Avatar
super easy fix...... turn the music up lol
Old Apr 1, 2010 | 09:38 AM
twentyhurtz's Avatar
^^^ i love this answer, i completely agree...
ha yea it sounds like the coil in a relay is causing the contacts to chatter..
Old Apr 3, 2010 | 12:01 PM
kinda sounds like its coming from the same area where the blinker noise would be.
Old Apr 3, 2010 | 12:02 PM
ok. ill go ahead and narrow it down to where the sound is coming from.
Old Apr 4, 2010 | 07:06 PM
I went to check it out again and the blinker is coming straight behind the steering wheel. Also I just noticed that when the blinker noise turns off, the doors automatically locks and when I looked under the fuse box I see a yellow and a red wire not connected. I don't know where the red and yellow wire connects to. Could this be the problem or does anyone know how to solve this problem.
Old Aug 16, 2010 | 05:29 PM
draco751's Avatar
Here's a quick thought for ya Marine! Check around under your dash for an old alarm system someone put in, and disabled by snipping a few of its wires. A friend's bmw that he had bought used had this happen. The previous owner didn't have the keyfob for the alarm so they just cut the wires for the horn, ign bypass, and light output, so the clicking relay was still going crazy all the time.
Semper Fi
~Fellow Cpl
0331
3531
Old Aug 17, 2010 | 06:09 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^
I would definitely look for something aftermarket, like an alarm, car starter or key-less entry.
Pull the lower dash trim and take a few pic. and post them. 94
RA61825
Sep 21, 2005 01:12 PM
mdaby3
Sep 12, 2005 04:45 PM
pburke23
10
Apr 24, 2004 12:31 PM
mr poo
13
Oct 19, 2003 07:24 PM
