BB/MC Replacement help
Old Mar 30, 2010 | 06:07 PM
VTEC_Honda's Avatar
Default BB/MC Replacement help
I am replacing my brake booster and master cylinder on my hatch and need to kno if anything special is going to be needed. I.e. - tools, gaskets, etc. I'm scraping both from my car and have a matching setup from a sedan if that matters.
Sorry if its a stupid quesion but I've never done them before and don't wanna mess anything up.
Thanks guys!
Old Mar 30, 2010 | 08:29 PM
VTEC_Honda's Avatar
Default Re: BB/MC Replacement help
Bump
Come on guys, I've looked through the faqs and didn't get my answer...
Old Mar 30, 2010 | 08:42 PM
EL Vap133's Avatar
You will need to bleed brakes, get a 10mm (IIRC) flare nut wrench, and maybe that gasket behind the MC that goes into the BB. Make sure you bleed correctly, if you have a friend it will be easier to bleed unless you got some special tools.
Old Mar 31, 2010 | 08:19 AM
VTEC_Honda's Avatar
Thanks Vap
Old Mar 31, 2010 | 09:17 PM
pearl95sc's Avatar
Invest in a powerbleeder if you have an air compressor or a vacuum bleeder if you don't. It will make things much easier. If your lines have any rust hit them with pb blaster prior to doing the work.
fbw2003
Jul 26, 2007 09:29 AM
sexycivicgirl87
Apr 2, 2007 07:51 AM
SiR AuToBoT
Aug 9, 2005 08:19 AM
crxtreme27
May 19, 2003 12:04 AM
