Got my mounts,now where do i put em?
Hi. I finally received my place racing engine mounts from a dude here on h-t (pinhead) who i might add was most helpful and a great guy to deal with. Anyways,i got three mounts which im almost positive is the full kit. Anyway,they came with no instructions and im not sure which mount goes where! i have an idea about one of them but the other two little ones, i have no idea. Can someone point me in the right direction? thanks. RYan.
i'm not familiar with the place racing kit but if its like the hasport one you'll have to bend/cut the front motor mount on the crossmember out of the way to clear the motor (since it wont be used). also you have to dent the left shock tower for the alternator pulley clearance. and last, you have to bend down the lip of the rear crossmember where the mount goes to clear it once you drop in the motor. like i said this is hasport, could someone verify if the same is true for placeracing?
hope this helps and good luck
CivicUtah
Sep 18, 2007 02:17 PM
rocketfuelcerx
Jan 21, 2005 01:23 PM
PYITR821
Apr 20, 2004 09:35 PM
MAD SCIENTIST
12
May 28, 2003 06:05 AM
