IS fuel fitlter upgrade needed??
Old Mar 30, 2010 | 03:59 PM
eg:R's Avatar
Default IS fuel fitlter upgrade needed??
Target hp is 500. Is it necessary to upgrade the fuel filter to a high flow filter?? I was planning on getting the aem factory look filter. The upgrade I have for my fuel is a 255walbro in tank, 1000cc RC, STR fuel rail, upgrade 6an line from fuel filter to fuel rail and fuel pressure shown 50psi. If it is not necessary I will just leave the fuel filter how it is. Thanks
Old Mar 30, 2010 | 04:13 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: IS fuel fitlter upgrade needed??
540 with a walbro, stock lines to the stock filter, -6 lines to the rail. basically like your setup. i think you will be fine.
Old Mar 30, 2010 | 05:11 PM
runsfromdacops's Avatar
you can make 630-650ish on stock lines and filter.. you will be fine
-alex
Old Mar 31, 2010 | 05:37 PM
eg:R's Avatar
ok, thanks a lot
B18IntegraLS
Apr 2, 2010 07:43 AM
Ej8_KiD
Oct 27, 2009 07:15 PM
green eyed bandit
Aug 15, 2007 11:27 AM
dustin
Oct 2, 2001 04:23 PM
