need help about headlights and map sensor!
where is the map sensor on a 91 hatch located? i did alittle research and it showed what is suppose to be a map sensor for my car, well i found it on my car, i believe it was behind the manifold on the firewall.....there was a couple other wires that went into the hose that goes threw the fire wall into the car, not sure what they were, dont know much bout cars.but i moved the carpet on the passenger side and there were about 4 different plugs, one was plugged into a little box and the other 3 were hanging loose...not plugged in to anything... i will have pictures up tomaro or later tonite..any help or advise to give on what they might be or if they have to be plugged into anything or not?
also im heading to the junkyard this week.just wanted to know if the headlights from a 91 sedan/coupe would fit perfect on my hatch? i also might pick up a front bumper because mine is cracked in the middle...will i need the front bumper from the sedan/coupe to make the headlights fit perfect if they dont fit on my hatch, if the bumper does fit my hatch, will it? im asking this because the junkyard says it has a 91 civic but wont say what it is so i just want to be sure before i go, and if i could find one.
any idea what the wires might connect to? there on the passenger side, ... ill post pics tomaro of what im trying to say.
