how to remove this pulley? (pics)
Old Mar 30, 2010 | 03:20 PM
dleccord's Avatar
Default how to remove this pulley? (pics)
this is the inner crank pulley from the main shaft on my f22b2 motor.
i am having a difficult time removing it.
I did spray it down with liquid wrench and wd-40 but the thing wont come off!
any suggestions?
Old Mar 30, 2010 | 04:10 PM
GlassJAw's Avatar
Default Re: how to remove this pulley? (pics)
Have you got access to a bearing puller??
The right sized bearing puller should pull that thing straight off with ease.
Why are you trying to take that off if you dont mind me asking??
Old Mar 30, 2010 | 05:04 PM
dleccord's Avatar
im trying to see if the sea leaking because my cam is leaking and oil drips down and i want to make sure this one isnt leaking as well.
thanks i will check it out, but isnt a pulley puller big? the ones ive seen are pretty big and im not sure if it has enough clearance.
Old Mar 30, 2010 | 05:50 PM
GlassJAw's Avatar
Good idea on replacing the seal whilst you got it stripped down, have you tried using a pry bar to try move it??
http://www.directindustry.com/prod/h...26-376020.html
Thats what I meant by bearing puller..... but I'm not sure how that back washer will go with the grips behind it??
Old Mar 31, 2010 | 01:22 AM
dleccord's Avatar
i did try to use a pry bar but not the flat ones you use for roofing. any theres not much you can wedge on since i dont want to damage any aluminum surface down there.
Old Mar 31, 2010 | 04:39 AM
nus_dogg's Avatar
Those usually slides right off. But it should slide out with ease if you pry it out with a flat head screw driver.
Old Mar 31, 2010 | 05:19 AM
TouringAccord's Avatar
H-T Order of Merit
like nus said, they usually just slide off.
by the looks of the picture it might be rusted on there a bit. since you have the key removed try rocking it back and forth in a spinning motion while pulling out on it.
Old Mar 31, 2010 | 06:24 AM
dleccord's Avatar
hmm not as easy as you guys are saying. i did use a channel lock on the pulley, trying to turn in but it would turn the crank, with the key out of the way.
Old Mar 31, 2010 | 07:18 AM
H-T Order of Merit
Just keep soaking it to break the hold the rust has on it. I prefer PB Blaster over Liquid Wrench, it just always seemed to work better for me.
you could try using a brass bunch and a hammer to try and tap the pulley loose. use a brass bunch because with it being a softer metal it shouldn't damage the pulley. If need be, put the pulley bolt back into the crank and use a socket/ratchet to hold it in place while you work on the pulley.
Old Mar 31, 2010 | 04:53 PM
bseriescrxsi's Avatar
slide hammer is another option
Old Apr 1, 2010 | 11:15 AM
dleccord's Avatar
ive only seen the slide hammer for pulling rotors, where 3 bolts are required.
Old Apr 1, 2010 | 05:03 PM
ive done some pulleys with them....a little harder but still doable..i shouldve said slide hammer with the pulley tool on it
y2kferari
Dec 26, 2008 09:57 AM
hu
Apr 15, 2007 07:34 PM
Adam.
Jul 28, 2005 07:35 AM
kapoosh valve
Jun 5, 2005 11:23 PM
Innovation
37
May 27, 2005 10:46 PM
