Is there a B Series Torque mount Bracket without ac?
Old Mar 30, 2010 | 12:25 AM
Budget Racer's Avatar
Default Is there a B Series Torque mount Bracket without ac?
I don't want AC and was hoping there is a bracket without one. Is there a difference? I am also looking to buy a set of B series torque mount brackets. I think the actual 00 Civic cx "mount's" will work but brackets need changed right?
I wish there were after market Torque brackets!! Maybe I should make some! lol
Thanks!
Old Mar 30, 2010 | 04:39 AM
94EG8's Avatar
Seagull Management
Default Re: Is there a B Series Torque mount Bracket without ac?
ITRs came with a lightweight aluminum A/C bracket, still setup for mounting an A/C compressor though. (for those with a D-series, VX civics came with a similar aluminum A/C bracket.)
Old Mar 30, 2010 | 08:00 AM
Thanks but what about my question lol? Is there one without AC mount? You know a less cumbersome oem mount. The b series one with AC looks huge and don't want it if there is a smaller one for no AC. I don't care so much about light weight as much as I am looking for a less crowded engine bay and clean look. I will not be using AC.
I just don't know....
Old Mar 30, 2010 | 08:18 AM
killahatch's Avatar
yes the integra type r bracket will work, i think you can also use the integra one. if your looking for a clean engine bay then dont use the torque mounts and brackets at all just buy stiffer mounts and you'll be fine. as for the actual torque mounts avid sells them in a set, there polyurethane and they work really good. im using them but the only downfall is you'll get alot of vibration from the inside. hope this helps
Old Mar 30, 2010 | 09:05 AM
tlarimer's Avatar
To answer your question, NO, whether you A/C or not, the only bracket I have been able to find or have ever seen is the bracket for A/C. The models that didn't have A/C just didn't have the compressor attached.
Old Mar 30, 2010 | 09:53 AM
Avistar23's Avatar
I have found the same.
Old Mar 30, 2010 | 03:30 PM
Thanks tlarimer and Avistar23. Finally an answer to my question and not an offshoot of it. Now I know when I see the bracket on ebay and it says AC torque mount bracket I know thats one I want! Thanks!!
Here Beers on Me :b eer:
endless_pain
14
Oct 8, 2022 10:48 AM
eghatch07
Jan 21, 2014 08:47 PM
LoneAutosport
Jun 11, 2007 07:36 PM
sigNAL_fiRE
Oct 17, 2005 07:31 PM
Soled Out
Jan 31, 2003 06:07 AM
