got my 92 h22a swapped in but..
Old Mar 29, 2010 | 08:54 PM
cvandulken's Avatar
Default got my 92 h22a swapped in but..
i'm getting a weird howling or harmonics or something... so far i've pulled the oil pan, oil splash shield and inspected.. touched every place my fingers could fit (i made sure my hands were clean before so nothing was left behind)/.. pulled the valve cover... fished everywhere with a magnet.. found some grit but that's about it... heres whats driving me crazy...
http://www.youtube.com/watch?v=8seH5_-SXYA
i've applied pressure to the muffler and cat, intake manifold when it makes it.. doesn't go away. oh and i should mention... its sorta random. doesnt do it all the time.. but when it does its at idle speed only... any slightest throttle makes it go away...
any help appreciated pleaaseee.. its driving me nuts.. i don't want to drive the car because the noise scares the **** out of me when it happens lol.
i posted this here because i need help with the motor mainly.. the car itself is a 1988 accord that has been converted to mid engine rwd, and this swap is supposed to be an upgrade from a 95 f22b2.
thanks for your time.
Old Mar 30, 2010 | 06:47 AM
cvandulken's Avatar
Default Re: got my 92 h22a swapped in but..
no one is even curious???
Old Mar 30, 2010 | 06:50 AM
backwoods's Avatar
pics of said swap?
Old Mar 30, 2010 | 06:59 AM
Acidcrakker's Avatar
Is that thing in your freaking trunk????!!!
Old Mar 30, 2010 | 07:05 AM
backwoods's Avatar
****...realized pics blocked at work...hrmmmmmm
Old Mar 30, 2010 | 07:40 AM
cvandulken's Avatar
i will put it up in the garage and post a link if you guys want..
any ideas on the noise?
Old Mar 30, 2010 | 07:54 AM
If all your mechanical stuff checks out in the engine, Id say it might be generating from the flywheel quiet possibly.
Check your valve leash, and oil your pulleys. Its hard to actually tell you what it could be with out actually being there.
Old Mar 30, 2010 | 08:03 AM
cvandulken's Avatar
yea i hear ya.. the direction the sound is coming from the engine itself... it changes from when to go front to back..
anyhow, for those who are curious.. i started a little build thread... here:
https://honda-tech.com/forums/showthread.php?p=42024279
i crawled all over it last night.. i spun the engine by hand checking various things... i've played with the clutch.. the only thing i can think of is balance shafts since they spin faster than the crank itself.. i was told to remove the belt.. i will probably do that tonight as a test.
Old Mar 30, 2010 | 08:38 AM
88_EE's Avatar
TRIAL USER
so ... uh .. .yeah.... nice corrolla
Old Mar 30, 2010 | 08:39 AM
cvandulken's Avatar
wtf?
Old Mar 30, 2010 | 09:18 AM
nsxter's Avatar
i had the same noise it was a loose flywheel
Old Mar 30, 2010 | 09:29 AM
cvandulken's Avatar
its been tq'd on there pretty good... 76lb/ft (stock tq isnt it?)
i ordered a new water pump, tbelt, vc/op gaskets.. going to convert it to manual tensioner as well while i'm doing all this just to be safe.
Old Mar 30, 2010 | 09:42 AM
samurhai's Avatar
loose pulleys?
Old Mar 30, 2010 | 10:44 AM
nsxter's Avatar
just because you torqued it dosent mean it cant come loose its no that hard to check
Old Mar 30, 2010 | 12:35 PM
cvandulken's Avatar
no i know.. i did push on it when i rotated the motor and it didnt budge all the way around.
Old Apr 4, 2010 | 04:36 PM
cvandulken's Avatar
alright, new timing belt.. and i built a manual bolt tensioner for the auto idler pully... and i left the the balancer shaft belt off...
the car no longer makes the noises in the video, so i'm led to believe that it was related to the balancer shafts... i didnt change the water pump. the water pump looked very clean and had 0 play in any direct so its good still. i'm not going to run a timing belt cover upper or lower i can change it anytime.
i'm putting a fully closed belly pan under the back of the car to protect it from weather, dirt, mud.. anything i could be potentionally driving the car through.. so it shouldnt be a problem and make further servicing in the future much easier as the cover bitch to get off in the first place. and another bonus to that it will keep the bay very clean.
i put synth 10/30 in it and went for an easy drive stopping at service stations, side roads etc... checking for noise, and there was nothing, so i'm confident it was the shafts.
thanks for the input guys, i will be updating the build thread as i go along.. i probably will post a mini howto about the home made tensioner.
HAccordH22
Apr 30, 2012 08:14 PM
epidemic
Aug 29, 2005 07:28 PM
jamal-188
May 14, 2002 10:20 AM
