Valve cover stud part #
Old Mar 29, 2010 | 07:21 PM
JasonYo's Avatar
Default Valve cover stud part #
Hey, I just want to know if anyone has the part number for the outer valve cover studs on a b16?
And the nut to, if they come separately.
Thanks
Old Mar 29, 2010 | 07:38 PM
egsleepercivic's Avatar
Default Re: Valve cover stud part #
http://www.hondapartsunlimited.com/i...%20%28V-TEC%29
90012-PM7-000 BOLT B, HEAD COVER 1995 DEL SOL 4.22 2.95
I usually keep an extra one around
Old Mar 29, 2010 | 07:42 PM
JasonYo's Avatar
Cool thanks!
Old Mar 30, 2010 | 10:01 AM
97civic02's Avatar
be very carefull putting these in...i broke two off when i first got my car so i ordered to from my local honda (there expensive as crap!) and snapped one of the brand new ones putting it in
Old Dec 10, 2012 | 03:58 AM
SPR876-B18C1's Avatar
i broke 2 while tighten back the valve cover after changing a gasket .. i googled the part number but i see mainly cr-v that it matches up to .. will these work on a b18 ??
Old Dec 10, 2012 | 05:18 AM
apexi_rsx's Avatar
yes all B series valve covers are the same....
Old Dec 10, 2012 | 05:48 AM
OK kool thanks man ..
Old Dec 10, 2012 | 12:32 PM
Mr Ohms's Avatar
Call me Cheeks
hey i just broke two of mine today. the threads of the screw are stuck in the valve cover. any way to take them out?
Old Dec 10, 2012 | 12:42 PM
i soon find out that .. when i do i pass that info on .. or if u do let me kno
Old Dec 10, 2012 | 01:41 PM
gzes's Avatar
Left hand drill dit and drill in reverse or weld a stud on the bolt. When i did my lift in my tahoe i blew a bolt and had to weld another bolt on to get it out
Old Dec 10, 2012 | 02:41 PM
Mr Ohms's Avatar
Call me Cheeks
will try tomorrow. thanks
Old Dec 10, 2012 | 05:01 PM
apexi_rsx's Avatar
That's what they make. Easy-outs for. If you can't use a screwdriver to turn it out then get a reverse drill bit or drill a small hole in it and beat a square easy out in it and turn it out.
Old Dec 10, 2012 | 06:08 PM
gzes's Avatar
Also if you dont have a welder just get 3 car batteries and hook em up in series. Kts redneck but works lol i dont own a welder so thats my arc welder
Old Dec 11, 2012 | 09:58 AM
Mr Ohms's Avatar
Call me Cheeks
I'm going to drill a small hole into the broken piece of the screw that's stuck in the valve cover and see if i can unscrew it. Is it likely that I further push the broken screw into the valve cover if I put too much force while drilling?
Old Dec 11, 2012 | 10:14 AM
apexi_rsx's Avatar
no it will evenually bottom out u wont hurt anything putting too much pressure on it. use wd-40 or motor oil to keep the bit cool it will drill faster and not burn the bit up if using a high speed
Old Dec 11, 2012 | 12:28 PM
Mr Ohms's Avatar
Call me Cheeks
Sweet. Thanks
Old Dec 12, 2012 | 02:57 PM
Mr Ohms's Avatar
Call me Cheeks
I was able to unscrew the broken bolt today using a drillbit in reverse. Worked like a charm. Thanks again
Old Dec 12, 2012 | 03:20 PM
gzes's Avatar
Np glad it worked for you
Dekorum
Dec 29, 2011 09:36 PM
liljohn850
Jun 5, 2009 04:23 PM
Acidcrakker
Oct 24, 2007 08:12 PM
tyco
Jun 20, 2006 07:44 PM
JDM_lover03
10
Oct 19, 2004 07:06 PM
