A couple questions about the fuel pump.
Old Mar 29, 2010 | 06:24 PM
the_asteroid's Avatar
Default A couple questions about the fuel pump.
Does anyone know which pins on the connector under the back seat are for the fuel pump? I want to check if the pump is getting voltage. Also would I have to drop the tank to replace the pump? It seems like it would just come out through the little access on the top of the tank.
Edit: The car is the '91 Civic Std. listed below.
Old Mar 29, 2010 | 06:44 PM
Default Re: A couple questions about the fuel pump.
NVM, it's become painfully obvious that the tank would have to come out and I'll just probe random wires to see if I get power.
Old Mar 29, 2010 | 06:52 PM
grant97teg's Avatar
first off, most all honda's grounds are black or brown,(toyota's-white wit black stripe and black) and not completly sure but should only be two wires. and that accsess whole your refering to under the seat is for the float sending unit. you'd have to drop tank to get to the pump. may not have to to test but not sure. on the 92-95 chassis you can remove threw back seat. test the power going to. the main relay first and the main relay it self
iamtwan
Aug 10, 2009 11:53 AM
tylertocker
Oct 11, 2007 09:00 PM
wumba
Apr 7, 2005 10:08 PM
vodavi6346
Aug 13, 2004 06:34 PM
