VTEC issue!
Old Mar 29, 2010 | 05:38 PM
BMO98GSR's Avatar
Default VTEC issue!
I have a 98 gsr and VTEC engages just fine, once in VTEC if you stop accelerating (holding it at a constant RPM) VTEC goes in and out. At first I thought it was my engine management so I installed the stock computer and Its the same issue. I would really appreciate it if someone could help me out with this issue. Thanks!
Old Mar 29, 2010 | 07:41 PM
mouab18c1's Avatar
Default Re: VTEC issue!
Try not to stop when Vtec engages.
Old Mar 29, 2010 | 07:56 PM
fsg231's Avatar
check your oil before anything!!
Old Mar 30, 2010 | 08:16 PM
BMO98GSR's Avatar
oil is always fine. It has done this since i purchased it three years ago. I just thought that I would look into the issue while I have the head ripped apart. So if anyone has any ideas or suggestions please bring them
Old Mar 30, 2010 | 10:01 PM
WDG_729_ITR's Avatar
I agree...the purpose of engaging VTEC is for more power, thus faster acceleration...if you're not trying to accelerate quickly, don't engage VTEC...if you need to stop, don't simply let off the throttle after VTEC engages and let it wind down, either shift to neutral or up-shift. You shouldn't really be cruising around in high-rpm's anyway, and unless you're accelerating, it shouldn't really sound like VTEC is engaging, it should be more like a high-rev sound.
Old Mar 30, 2010 | 10:27 PM
94GSRMR's Avatar
check the solenod? check your vtec wires going to the ecu, but your problems needs a video...
Old Mar 31, 2010 | 03:16 AM
BMO98GSR's Avatar
I agree with you. I am not saying that it is a huge problem, hence why I am just getting around to it three years later after the purchase. I just want to fix it while I have everything apart. Its obviously a pretty abnormal problem, I have heard of anyone else with this issue. I really do appreciate the help
Old Mar 31, 2010 | 03:18 AM
BMO98GSR's Avatar
I am waiting on new valves, so whenever I get them in and put the motor back together I will make a video of it. I will be sure to check the wires and solenoid. How do you test a solenoid to see if it may be going bad?
Old Mar 31, 2010 | 07:01 AM
Hope this helps:
https://honda-tech.com/forums/forced-induction-16/vtec-solenoid-troubleshooting-fixing-solenoid-itself-2480996/
98savage
Apr 15, 2007 09:23 AM
vietnogi
Apr 13, 2005 10:01 PM
lmiguelvv
Oct 19, 2004 06:55 PM
CompressionFed
Mar 23, 2004 04:54 AM
9deuce9rr
Mar 15, 2004 08:00 PM
