Si to ZC, Can you swap fuel rail and plug wires?
The ZC I got has a majorly j4x0red fuel rail, one of the injectors is missing the rubber rings that holds it in, another doesn't have the bottom plastic piece which I hope is not in the fuel rail. Can I just swap my fuel rail off my Si? Also are the plug wires interchangable?
Someone has to know this, they look the exact same... I know you can use the Si throttle body would this mean for any reason you can use the Si Fuel Rail?
u can use ur si fuel rail and washers..
also whiel its out pull the injectors and spray them with nonchloronated brake cleaner for a cleaning..
pelotudo
15
Feb 8, 2003 08:32 AM
