H22A1 Head Screwed
Old Mar 29, 2010 | 01:40 PM
TheFoshizzler's Avatar
TRIAL USER
Default H22A1 Head Screwed
Sssooo, I recently bought a '95 VTEC Prelude with the encouragement of a few friends (sold my crappy '98 Sentra prior). So after a few months of driving it, the auto tensioner decided to stop working, thus screwing the timing up and bending a few valves in the process. I just wanted to see where I go from here. Would it be better to just buy a used head? Or should I get the machine work done to repair mine? Anything helps, thanks guys.
Old Mar 29, 2010 | 04:12 PM
cr0c0's Avatar
Default Re: H22A1 Head Screwed
The 4th gen H22A1 came with manual tensioners, not automatic ones. Regardless of what happened, the safest bet is to get a used but known to be in good shape head.
Old Mar 29, 2010 | 04:37 PM
ilikehonda's Avatar
dont listen to the noob. your car did have an auto tensioner. if you decide to keep it that should be the first thing that you replace. If you bent a valve you will need to at the very least puchase new piston(s), a hone (good luck finding somone who knows what they are doing, and some new valves.
you may have got lucky and the valves didnt break off and tear up the pistons or the cylinder walls. there are places that will rework the head so that it is usable.
but if too much work is involved you can pick up a long block for under a grand.
Old Mar 29, 2010 | 04:43 PM
NirVTEC's Avatar
why would bending a valve require new pistons?
H22A1=Auto tensioner
H23A1=Manual tensioner
I think just buying a used head, swapping it, and then selling the old head may be the easiest way to do this.
If you search around, you will find a thread on the Auto to Manual tensioner swap that includes a parts list.
Old Mar 29, 2010 | 05:01 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Seriously?? Look up the term interference engine...
Old Mar 29, 2010 | 05:11 PM
NirVTEC's Avatar
I know the term.
I can't say every H22A thats broken a TB has destroyed the whole engine...
prion's Avatar
I've never checked out pistons on an H22 after they hit the valves, but I've seen many other interference motors after a timing slip, and never had to consider changing pistons to get those engines running again. Usually the valve (or other head componentry) takes the only real damage.
OP - I'm sure that one look at the pistons with the head off will tell you what you need to know.
Old Mar 30, 2010 | 05:41 AM
ilikehonda's Avatar
well generally when you have a bent valve it is because it hit something....like a piston. if it hit the piston hard enough it could have damaged it....notice i said he may have got lucky and the pistons etc were not damaged. I know that you know this.
depending on the condition of the head you can have it repaired for as little as 100 bucks.
good luck
Old Mar 30, 2010 | 06:16 AM
backwoods's Avatar
Manual Tensioner Conversion saves lives....
Old Mar 30, 2010 | 08:26 AM
NirVTEC's Avatar
For sure.
Have people had complete engine damage from the TB breaking? Of course, but its not a definite thing every time.
It would be like saying every time you bent a valve from a mishift that you needed pistons.
Pull the head, start from there....
Old Apr 1, 2010 | 02:57 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
I know the term.
Well you asked why bending valves would require new pistons so I assumed you did not know what an interference engine was. While its true he likely will not need new pistons it is a very real posssibilty that he may.
Weck
Jul 22, 2014 07:37 PM
dwarfsinhondas
Apr 15, 2011 04:06 PM
AntMan401
Mar 17, 2008 02:13 PM
VegaS10
Oct 29, 2006 06:23 AM
