type s cams...again
so i have been on ht today for about 4 hours reading every thread about puttin type s cams into a regular h22 but there IS NO DEFINING ANSWERS about if they work? can somebody tell me?? and please if ur gunna say research it I ALREADY DID!
They work hard producing stock or minimally above stock #s.
IIRC people have talked about using the TypeS/EuroR valvetrain with them also.
I recall seeing in one of the threads that the higher lobes cause problems with the valve guides if I remember, although that might be with the VT swap as well. Would certainly recommend swapping in the VT since it is properly designed for the slightly more aggressive cams. Hopefully one of the head gurus will stop in soon to chime in...
