HELP! My power locks and windows dont work
ok, im getting tired of my windows not working cuz its getting close to summer. the wires that plug into the switches is not getting any power... also my speakers stop working also... when the power windows and power locks were startin to stop workin... i would have to open my door about half way and then i would be able to roll my windows down and the power locks would work... now they jus dont work at all... i used my volt meter and didnt get anything from the wires... i checked the relay and fuses they're all good... could it be a bad ground? someone help!!
my brothers 02 explorer is doing the SAME damn thing. best i could figure is a loose wire some where. also check and see if any fuses are blown. his also stopped giving any power through the wires going to his switches. ended up being a blown fuse, but still cant find the bad wire causing his window/lock problem.
Get the wiring diagram. Work your way back from the switch connector if you don't have power there. Go to the next stop such as another connector or plug in.
solsi2000
20
Jul 16, 2008 08:20 PM
4playEkay
Mar 31, 2005 10:48 PM
Accurate GS-R
Sep 29, 2004 05:44 AM
MestizoRacer310
Nov 25, 2003 10:57 PM
