cp piston wrist pin
Old Mar 28, 2010 | 10:34 PM
hondah2b21's Avatar
Default cp piston wrist pin
hi i was wondering whats the max power made on a standard cp piston wrist pin.
im building a fully built h22 but i forgot to upgrade the wrist pin. i would hate for that to be my down fall on my build.
if this question is in the wrong location i apologize.
Old Mar 29, 2010 | 04:51 AM
Mikey3000's Avatar
Default Re: cp piston wrist pin
Nobody is going to have an answer that's worth a damn. Your best bet would be to call CP and ask what they're designed to handle.
Old Mar 29, 2010 | 07:01 AM
hatch34's Avatar
a close friend of mine made 700whp on off the shelf CP pistons
Old Mar 29, 2010 | 07:35 AM
narfdanarf's Avatar
when I called CP and asked them they said between 5 and 600, but there are people on this forum making 1000ish on stock wrist pins...I personally have the upgraded ones just for peace of mind.
Old Mar 29, 2010 | 08:40 AM
hondah2b21's Avatar
thanks guys.
my budget is on its final string so i think im just gonna run the standard wrist pin and get the car dialed in. then upgrade when my money back to par. gonna enjoy what i have for now. thanks again.
Old Nov 25, 2011 | 02:33 PM
HybridKOOP's Avatar
for those who have upgraded pins (primarily CP), did you have to hone out the small end of the rod and/or wristpin opening in the piston to add clearance? or did you just run the upgrade .180 wall pin in the standard piston and rod? Thanks!
Lou
Old Nov 25, 2011 | 02:40 PM
gringotegra's Avatar
On all of our engines, we have them Pin fit at the machine shop. Wiesco/JE/CP all of em. You'd be surprised how off some of them are.
Old Nov 25, 2011 | 02:42 PM
ashtons300zx's Avatar
Its usually just a thicker wall pin same outer diameter, inner diameter is smaller and the material is of course stronger. Why not just upgrade pins, its like 75 bucks more to upgrade wrist pins. I ran my standard pins to 650+whp without problems but im not chancing it with the new power goals of 800+, not much money for peace of mind.
Old Nov 25, 2011 | 02:57 PM
cibao2ner's Avatar
yea you always need rods hone at machine shop...they come tight....
Old Nov 25, 2011 | 04:03 PM
HybridKOOP's Avatar
Thanks guys. I was told by some popular vendors on here to just slide them in and run them without pin fitting. Anyone have a spec of what kind of clearance they should have? I'm running CP Pistons with their 9210 upgraded pins. Same outer diameter etc, just a slightly smaller hole in the middle. Thanks.
Lou
Old Nov 25, 2011 | 04:52 PM
zakura R's Avatar
My h2b made last year on 9.1 comp cp piston with stock wrist pin that they came with 831hp at 33psi never had any problem with it I will said that u will have to worry when u start making over 900hp plus just my opinion
Old Nov 25, 2011 | 06:43 PM
carbon fiber coupe's Avatar
i'd just save up the extra 150 and get the upgraded wrist pins
It's just a little piece of mind
Old Nov 25, 2011 | 06:59 PM
boostedeg6-1's Avatar
Hey, I think I know that guy your talking about... Oh wait, that guy was me haha!
I made 700/500 on stock wrist pins revving to 10200-10400 and beat the living hell out of the car, never had any problems. Wrist pins and pistons themselves looked great after 5k miles. Spun a bearing so got a chance to check them!
Old Nov 27, 2011 | 05:13 PM
KStuned's Avatar
The wrist pins will outlast the off-the-shelf CP pistons at that RPM and power level. You'll eventually finds cracks at the base of the skirt. The non-strut design just can't deal with the abuse. The off-the-shelf pistons will last about a full season though... but when you're ready for a piston that really can deal with the abuse, we have these:
The underside looks like this... it's just an iphone pic but if you look closely you'll see the cracks in the corners of the skirt. Our HD piston has a strutted skirt to keep the skirt from flexing, cracking and collapsing.
Old Nov 27, 2011 | 05:28 PM
JJsMotorsports's Avatar
Those are some strong looking pistons Reid!
Old Nov 27, 2011 | 05:36 PM
SPOOLINmatt's Avatar
doesnt really make sense to me why they wouldn't manufacture the shelf version like that. People will still destroy it, but from melting rather than collapse.
Old Nov 28, 2011 | 06:26 AM
HybridKOOP's Avatar
Those pistons look sick. Much beefier.
For those who are wondering about pin fitting, I am sending my pistons, rods, and upgraded CP pins to my machine shop today. I'll let you know the results. I am thinking no change will be necessary as the upgraded pins slide smoothly (if not even looser) into the piston and through the rod than the shelf pins do.
Lou
Old Nov 28, 2011 | 07:58 AM
zakura R's Avatar
Reid are those piston the hd wiseco ??? One 10.1 comp ????
Old Dec 1, 2011 | 07:55 AM
HybridKOOP's Avatar
Lou
FWIW, and for future searches that bring this thread up... I DID need to pin fit the upgraded CP pins. CP's tech told me that the upgraded pin is more ductile and needs a little "flex" or "give" compared to the standard pin. He suggested .001 to .0012 clearance in the piston hole, and .001 in the small end of the rods bushing (which is what my machine shop did for me.)
Lou
Old Jan 7, 2012 | 05:57 PM
jsilva's Avatar
That must have been in the motor I bought from you but you never sent me right? The one you scammed me on. Man it either takes stupidity or ***** to come on here and still post about the parts that you scammed me on. Im still waiting for my $1500 refund and dont worry I wont forget about it either.
Old Jan 8, 2012 | 01:19 AM
SLIM NOTHING's Avatar
Originally Posted by hondah2b21
thanks guys.
dude the upgraded wrist pins for 1000hp+ from ipgparts.com are only $99.
Old Jan 8, 2012 | 04:13 AM
rudebwoy's Avatar
you DO NOT!!!! need to machine anything to run upgraded Wrist pins. the inside diameter of the upgraded pin is smaller therefore a thicker side wall, outer diameter remains the same as the standard pin. as stated earlier... I can associate it like this say you are running 24.5 slicks on 15" rims, an uprgade would be to run 24.5" slicks on 13" rims would give you bigger side walls without increasing the diameter of the tires. hope this helps.
Old Jan 8, 2012 | 07:35 AM
MikeySpec's Avatar
I went 760ish whp(dynojet) at 30psi for about 20-25 hits(including track+street passes). Then we we went 33 psi at the track once it ripped the wristpin right our of the piston and kabaaaam'd everything. It was CP's 11.5:1 shelf piston.......that was a bad idea.
Old Jan 8, 2012 | 08:16 AM
MR.johnson's Avatar
This is why I'm running diamonds this year.
Lindomar85
Sep 7, 2013 05:09 AM
thegatekeeper14
Jan 18, 2011 04:18 PM
TheoneTheycallVille
Oct 20, 2009 06:01 PM
gaskleppie
Apr 14, 2004 09:34 AM
WICKED2
Nov 6, 2002 09:28 AM
