Is F22 Manual Trans and H22 Manual Trans are exactly same?????
Old Mar 28, 2010 | 09:38 PM
kamranm3's Avatar
Default Is F22 Manual Trans and H22 Manual Trans are exactly same?????
Guys please tell me if they are exactly the same. because i wanna swap my lude
Old Mar 28, 2010 | 10:02 PM
slomofo's Avatar
GDD Member
Default Re: Is F22 Manual Trans and H22 Manual Trans are exactly same?????
Gearing is different, driver's side axle is different, and halfshaft is different; other than that, they're the same.
The transmissions are interchangeable, if you want to put an H22 in your F22 car, it'll work, just use the halfshaft that matches the axle and you're good to go.
Old Mar 28, 2010 | 10:20 PM
kamranm3's Avatar
My prelude is auto , and i wanna swap my friend said F22 and H22 is the same, i wanted to make sure.My other question is, Which Trans do you prefer F22 or H22, which one is better for a 97 prelude
Old Mar 29, 2010 | 12:30 AM
Kronn 98SH's Avatar
https://honda-tech.com/forums/honda-prelude-4/prelude-h-series-transmission-codes-ratios-master-list-2548441/
There are multiple H22 transmissions and multiple F22 transmissions, each with different gearing.
Old Mar 29, 2010 | 05:16 AM
Sonin Fury's Avatar
F22 gears are longer than H22
Some people prefer to use the F22 tranny when boosting so they dont have to shift as often, However, some people also do H2B with a b16 tranny on boost and have to shift as soon as they get it in gear
It is mostly a preference thing based on what type of build you are going with
My friend has a H2B LSD del sol with full bolt ons and he just barely passes me in my stock H22 EK coupe (Lightened Dx) so in my opinion the H2B is not worth the cost
Old Mar 29, 2010 | 06:05 AM
Kronn 98SH's Avatar
^ You failed. ^
Read my post again. Also, this is a Prelude thread. No one does H2B on a Prelude.
92civlude
Jun 1, 2009 01:16 PM
slickrick88_2006
Apr 1, 2007 07:56 PM
crvtec10
26
Sep 8, 2006 03:34 PM
jasonyap
Sep 28, 2005 09:30 AM
