couple build questions - MASTER TECHS ONLY
So im building a JDM front gsr turbo, engine swap, turbo kit and the front are done. I need to get a couple things done.
A) whats the easiest way to do the headlight harness tuck? I tucked the engine harness when i oput the swap in.
B) whats the easiest way to shave a bay?
C) what exactly do i need to remove abs?
Harness tuck thread
Brake tuck thread
a) Head light harness = remove your fenders and run the harness under the fender.
b) Question is too broad to answer completely but you will need to fill the unused holes with welds(spot welds), use putty and the proper tools to make everything smooth and then add paint.
c) You will need a non-ABS proportioning valves and lines (either tuck lines or non-abs lines).
Brake tuck thread
The best thing to do is to take a couple of hours on an off-day and look through the FAQs. Most of what you're asking for has already been done in detail with a write-up and pics.
Being in a hurry with a build will get you NOWHERE. I started my mild build including an engine bay shave, tuck, and motor that has taken me nearly 9 months and I'm still finishing up small things.
Details are everything.....
^ very true.never speed things up,it will only lead to disaster. patients and organization is key when doing something big like this.
Alex Flores
Sep 5, 2015 01:00 AM
kreatekustomz
Appearance Build Threads
Sep 13, 2009 06:24 AM
