Temp gauge runs hot but car makes no heat...... HELP
Old Mar 28, 2010 | 07:24 PM
boostjunkieee's Avatar
Default Temp gauge runs hot but car makes no heat...... HELP
I have a stock 97 Civic DX coupe. A few days ago while driving I noticed the temp gauge was running hot, sometimes real hot, i turned on the heat to try and get it to go down but all it was blowing was cold air. I figured my theromstat was going bad so I replaced that and it did nothing. So then I spent 7 ****ing hours tearing the dash out to replace the heater core and that also did nothing to fix the problem, it made it worse. Im stumped on what it could be, maybe a clogged radiator?? Any help would be awesome, im losing my patience fast and I have a real big hammer close by.
Old Mar 28, 2010 | 07:29 PM
Default Re: Temp gauge runs hot but car makes no heat...... HELP
Stock Y7 and no CEL's also.
Old Mar 28, 2010 | 07:36 PM
dmeconitas's Avatar
the only time that happened to me was there was no coolant in the radiator. The heater gets it heat from the hot coolant. So either you have no coolant, or you have a clog somewhere.
Old Mar 28, 2010 | 07:41 PM
Its full of coolant. Im thinking a clog also. I might let it run for a while tommorow and check the hoses to see if any are cold. ran out of daylight today.
Old Mar 28, 2010 | 07:42 PM
shwanC's Avatar
It could be the heater control valve for the heat (or clogged heater core lines). It is what the temp. slider is attached to. This is between the engine and the heater core (under the hood). This might be the problem for no heat, but does not answer why the car is overheating. It could have been low on coolant, and boiling out. This could be caused by a faulty rad. cap, not keeping the pressure up. Also, since you changed the thermostat, make sure the coolant is bled properly, open the reliefe valve (somewhere around the thermostat) and run the car till the rad. fan turns on. Coolant will pour out, close it when there is no more bubbles coming out. If the car overheats while sitting, it could be a faulty fan switch.
Quickest and cheapest way first, change the cap and re-bleed the coolant system.
dmeconitas's Avatar
this isnt environmental friendly, but you could put a hose in the radiator and remove hoses and see if water is coming out. You need to remove the t-stat though.
Old Mar 28, 2010 | 07:43 PM
92lxsleeper's Avatar
well if the temp gauge is reading hot then there is coolant in the system. cause if there was a leak, and it was empty and overheating, the coolant guage would probably read normal since there is no coolant to heat up the temp sender.
Old Mar 28, 2010 | 07:49 PM
Temp slider seems to be working fine, checked it thoroughly on both ends. I'll take out the heater control valve tommorow as well to make sure its not clogged. Rad cap is new. Going to bleed the system tommorow also. Hopefully it works. Ill keep it updated.
Old Apr 14, 2010 | 12:26 PM
The problem was the brand new thermostat was bad. I popped it out the next day and let it idle to to see if any hoses were cold, they were all warm so i knew it was bad. All this work for a $17 piece of **** defective thermostat.
Old Mar 21, 2015 | 08:02 AM
HondaDieHard's Avatar
Dare I mention.. your new thermostat was probably okay. The problem was likely that you installed it backwards!
Old Mar 21, 2015 | 08:11 AM
Former User's Avatar
Ancient thread locked.
TOO MUCH TORQUE
Jul 28, 2010 09:21 PM
flatblk
Dec 7, 2006 12:04 AM
Kyles ej1
15
Jun 29, 2005 05:17 PM
Ti3d in
Aug 4, 2004 06:38 PM
superstud
Mar 14, 2004 08:54 PM
