currently doing a head gasket job, quick question
so i took off the head today for the first time
removed the intake manifold, headers and all the hoses/etc
i was able to slide off the timing belt.
how would i go about putting the timing belt back on? this is on a stock ls automatic. thank you
Here's a similar thread...hope it helps...
http://www.************.com/forums/s....php?p=2371381
it's "prelude power"...where the *** are...I guess it marked it as profane...
Basically you line up the white mark on the crank pulley with the line on the timing belt cover, which is TDC. Then with the cam gears UP marker pointing up and the timing belt tensioner bolt loose, slip on the belt. tighten the tensioner bolt, rotate the crank ccw a few times to see if everything stays lined up. Then set the crank to TDC, loosen the tensioner bolt, rotate the crank ccw three cam gear teeth and retighten the tensioner. You should probably get a manual for the full details.
b00st Junkie
Jul 24, 2010 07:29 PM
