can i use a lightend crank pulley of a ls/gsr on my 1st gen B16??
Old Sep 9, 2002 | 12:40 PM
takeheed's Avatar
Default can i use a lightend crank pulley of a ls/gsr on my 1st gen B16??
same block right?
Old Sep 9, 2002 | 12:44 PM
EF8_SiR's Avatar
Default Re: can i use a lightend crank pulley of a ls/gsr on my 1st gen B16?? (adamjoey)
Get the B16A one - 99 civic si or del sol vtec. The GSR one should work too I believe.
Old Sep 9, 2002 | 12:45 PM
takeheed's Avatar
Default Re: can i use a lightend crank pulley of a ls/gsr on my 1st gen B16?? (EF8_SiR)
so it will work then?
Old Sep 10, 2002 | 11:06 AM
EF8_SiR's Avatar
ls and gsr is diff....
gsr
ls
Question though: why do u really want a crank pulley? Yes it's smaller and lighter but think about it, the only accessory u really got is the alternator (unless u got a/c too). The gains aren't that impressive anyways, I'd say average 2whp. Also u r taking the risk associated with harmonic oscillation - especially the 3rd order one which can coz u to spin a bearing - say good bye to engine.
Some ppl say that the harmonic damage don't exist on older engines, but I didn't wanna take a chance so i sold mine. Is it worth taking the risk to find out the truth for an all impressive 2whp. In the end the decision is still urs...just my $0.02
Old Sep 10, 2002 | 12:47 PM
takeheed's Avatar
i appreciate all the extra info, but you still havent answered my ******* question!
WILL IT FIT RIGHT? my stock one broke after it fell off my workbench and i need one quick. everyone i talk to says there on backorder but this one guy has one but its for a ls/gsr.JESUS CHRIST
Old Sep 10, 2002 | 12:51 PM
takeheed's Avatar
sorry to blow up like that.i do appriciate the info and that does make sense.but the question still remains.
Old Sep 10, 2002 | 01:36 PM
EF8_SiR's Avatar
Maybe u just didn't understand my post. The crank pulley should be diff between ls and gsr (one being vtec and other no); and that's why i said yeah, use the gsr one (i even put a thumbs up beside it)
But maybe i'm wrong in them being different cranks - but even then YEAH U CAN USE EM.
Old Sep 10, 2002 | 05:44 PM
DTAYLOR's Avatar
New User
All b motor have the same crankshaft size so it will bolt up. I think that the pulley could look a little diffrent but it should work. I have a ls bottom end and I just ordered a type-r one to replace my bent LS one. Honda only makes one CTR n1 crank pulley to fit all b motors.
Old Sep 10, 2002 | 05:50 PM
takeheed's Avatar
Default Re: can i use a lightend crank pulley of a ls/gsr on my 1st gen B16?? (DTAYLOR)
THANK YOU VERY MUCH!! but now im all paranoid about spinning a bearing!
Old Sep 10, 2002 | 06:11 PM
chhuong's Avatar
Shave your stock one down to only the alternator belt and get it balance, and the harmonic dampener will still be there and it will be a lot cheaper, It will also be lighter. So best of both worlds, with less costs!!!
Zazz
May 2, 2009 07:54 AM
JMinSi2000
Jul 16, 2003 06:45 PM
IM ALL BOB
Dec 15, 2002 03:40 AM
GokuSSJ4
Mar 3, 2002 02:13 PM
