Remove head?
Old Mar 28, 2010 | 03:20 PM
RDAYA0's Avatar
Default Remove head?
Was working on fixing one of my bolt hole threads that hold down my valve cover, but i dropped a drill bit into a hole that i think leads to the block/oil pan. Shoud I remove the head or the oil pan to get this drill bit out?? i can't start my car with this thing inside my engine.. please help!! car is a 94 civic dx coupe with a d16z6
Old Mar 28, 2010 | 07:12 PM
Jockone's Avatar
Default Re: Remove head?
Can you try using a magnetic pick-up tool?
Old Mar 28, 2010 | 08:20 PM
xide_12's Avatar
Yea they have this little magnet on the end of a antenna like pole. Its like $2-3 dollars at a hardware store.
Old Mar 28, 2010 | 08:48 PM
93egSLEEPER's Avatar
if you think it goes down to the oil pan why not drain the oil and just pull the oil pan off to get it out? pulling the head wont help you any there.
Old Mar 28, 2010 | 10:23 PM
boxeocampeon's Avatar
yeah def try drainging the oil or using the magnetic pick up
Old Mar 29, 2010 | 12:17 AM
95soul's Avatar
If it went down an oil passage then your definatly gonna have to remove the head. Its not simply a hole going down to the oil pan, try the magnetic wand method first. if that doesnt work, then remove your head. hopefully it didnt make its way into the block.
Old Mar 29, 2010 | 03:23 AM
hondamark35's Avatar
Originally Posted by 95soul
If it went down an oil passage then your definatly gonna have to remove the head. Its not simply a hole going down to the oil pan...
yes, it is.
Old Mar 29, 2010 | 07:00 AM
TurboTron's Avatar
I'ts probably sitting upright on your block right now. #1 Magnet...#2 Oil pan removal + oil pick up unit...#3 remove head.....sorry for your butter fingers cause that sucks
Old Mar 29, 2010 | 08:46 AM
RDAYA0's Avatar
i know will be getting a magnet, thanks for the input people...ill get back to this
RDAYA0's Avatar
anyone got a diagram of the head/block assembly for a D16Z6???
Old Mar 29, 2010 | 11:11 AM
JDM8o9's Avatar
lol do not start the car
Old Apr 1, 2010 | 07:08 PM
RDAYA0's Avatar
Bit fell into this hole, looked down in it with a flash light best i could im pretty sure to myself that its an oil gallery that leads directly to the oil pan...lisenced or advanced technician's please chime in... should i just drain the oil and remove the oil pan to see if its sitting in there? thanks
Old Apr 1, 2010 | 09:30 PM
thumper64's Avatar
Just drop the pan...and weld a bung on for a turbo oil drain and turbo the motor while you're at it.
Old Apr 1, 2010 | 10:25 PM
RDAYA0's Avatar
lol k
Old Apr 1, 2010 | 10:30 PM
RDAYA0's Avatar
That was my friend who is retarded... but really does that passage lead to the pan?
Old Apr 1, 2010 | 10:33 PM
Davidkak's Avatar
ima be removing the same head of this motor for a buddy tom. ill let you knoe where that hole leads to!
for sure dont start the car wit that! lol
Old Apr 2, 2010 | 12:24 AM
millertime191's Avatar
iam sayin start it and then u will be a able to find it when ur motor is blow up layin in peices in ur garage jk dont do that ! i would say drop the oil pan look around in there for that son er bi*#Th not lik it grew legs and walkd away got to be in there some where
Old Apr 2, 2010 | 01:34 AM
DCRB's Avatar
attempt to use a magnetic tipped stick first. that is one of the oil drain holes. i put probably about 1000 miles on my car with a bolt just chillin at the bottom of my oil pan... hard miles. only found it out because i starved it of oil and spun a bearing (that motor was on it's last legs any ways)
Old Apr 2, 2010 | 04:14 AM
Neuspeed373's Avatar
There is also another tool that I use alot it looks like a plumbing snake but has a miniture claw that grabs things when you push on the top. works great for nonmagnetic items.
Old Apr 2, 2010 | 07:01 AM
RDAYA0's Avatar
Davidkak - that would be a lot of help bro, get back to me k? thanks!
millertime191 - i will do man when all else fails
Neuspeed373 - tried this one i bought at a local hardware store but it's not long enough the passage is too far down which got me thinking it's the main oil gallery to the oil pan but i need to find out for sure before i start ripping stuff apart.
thanks for the feedback
Old Apr 2, 2010 | 07:35 AM
Red_Army's Avatar
just do it. save the oil if its good.
otherwise its like 8 bolts and new oil take you maybe a half hour. and your troubles will be over.
Old Apr 2, 2010 | 07:55 AM
jooky5's Avatar
take a small tube and see how far if will go down the rabbit hole..then you will have a better guess as to how far down the bit fell.
riS.I.R
16
Sep 26, 2009 04:11 PM
jdmdohcvtec91DA
Jul 6, 2009 09:03 PM
Hondapreludeg
Apr 20, 2008 09:52 PM
jonnythan
May 23, 2007 11:29 AM
bluecb7
Mar 14, 2004 04:51 PM
